Introduction
The Samsung Galaxy Note 10.1 is a popular tablet that provides a wide range of features and functions for its users. However, after prolonged use, the device's battery may begin to deteriorate, leading to decreased battery life and other issues. If you find that your Galaxy Note 10.1 isn't holding a charge as long as it used to or is experiencing other battery-related problems, a battery replacement may be necessary to restore your tablet's performance. Replacing the battery in a Galaxy Note 10.1 can solve a range of issues, including charging problems and general battery health concerns. While the process of replacing the battery does not require any special soldering skills, it does require some technical expertise and care to avoid damaging the device during the repair.
This is the back of the device and where you will begin to take it apart
It is neccesary to remove this piece first before removing the bigger back piece.
Use the plastic opening tools to pry along the indicated box.
Lift up the silver piece to reveal the rest of the back cover.
Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
Remove the back cover.
Carefully remove all of the ribbons that connect over the battery.
Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
Disconnect the battery connector from the motherboard.
Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
52 other people completed this guide.
13 Guide Comments
In Step 3, mention that you need to lift up on the black locks to take out the ribbons.
Also, mention that you can disconnect the battery from the device by gently pulling out the battery and gently lifting up the wires.
When replacing the back cover, hook the bottom edge into the frame along the edge before trying to snap the rest in place along the sides.
