Samsung Galaxy Note 10.1 2014 Battery Replacement
  1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: step 1, image 1 of 2 Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: step 1, image 2 of 2
    Tool used on this step:
    Spudger
    $2.99
    Buy
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Battery Replacement, Battery: step 2, image 1 of 1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Battery Replacement: step 3, image 1 of 1
    Phillips #000 Screwdriver
    $5.49
    Buy
  4. Samsung Galaxy Note 10.1 2014 Battery Replacement: step 4, image 1 of 2 Samsung Galaxy Note 10.1 2014 Battery Replacement: step 4, image 2 of 2
    Spudger
    $2.99
    Buy
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
27 other people completed this guide.
Joseph Rasico
2,200 Reputation
6 Guides authored
USF Tampa, Team S1-G6, Leahy Spring 2017 Member of USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Members
7 Guides authored
5 Guide Comments
Step 1 you have to show the back cover to remove. Showing the front side is confusing.
After step 4 there should be a step 5 to show how to disconnect the white connector with the colored wires: it took time to discover that you have to lift the 2 side clips, and not to pull…
prisca - Reply Share
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
Matt - Reply Share
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Stephen Nichols - Share
Followed the instructions. Worked nearly perfectly. The last step is a bit tricky. Just look at the new battery to understand the system.
Eramur - Reply Share
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
Bradley Carr - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 95
All Time: 23,698
