Samsung Galaxy Nexus Main Display Glass Replacement
    1. Samsung Galaxy Nexus Main Display Glass Replacement, Removing Back Cover: step 1, image 1 of 1
      • Open the back cover of the phone with your fingers or use the plastic opening tools to pry the back cover off of the phone.
      • Remove the battery by prying it free from the divot at the bottom.
      • Store the back cover and the battery in a safe place, such as a bowl, until you are ready to re-install them.
      Ask FixBot
    2. Samsung Galaxy Nexus Main Display Glass Replacement: step 2, image 1 of 1
      • Remove the four 4.5 mm Phillips screws from the rear of the phone.
      Ask FixBot
    3. Samsung Galaxy Nexus Main Display Glass Replacement: step 3, image 1 of 2 Samsung Galaxy Nexus Main Display Glass Replacement: step 3, image 2 of 2
      • Flip the phone over so that the screen faces upward.
      • Insert a plastic opening tool into the seam between the screen and the outer case. Work the plastic opening tool around the phone without removing it from the seam.
      • Slowly pry the outer case from the screen.
      • Work carefully. Excessive force can easily damage the case.
      Ask FixBot
    4. Samsung Galaxy Nexus Main Display Glass Replacement: step 4, image 1 of 3 Samsung Galaxy Nexus Main Display Glass Replacement: step 4, image 2 of 3 Samsung Galaxy Nexus Main Display Glass Replacement: step 4, image 3 of 3
      • Remove a single 4 mm Phillips #00 screw from the bottom of the phone.
      • Lift up the flat connector from its socket on the motherboard.
      • Lift the entire headphone jack assembly from the phone.
      Ask FixBot
    5. Samsung Galaxy Nexus Main Display Glass Replacement: step 5, image 1 of 2 Samsung Galaxy Nexus Main Display Glass Replacement: step 5, image 2 of 2
      • Disconnect the two ribbon cables from the motherboard.
      Ask FixBot
    6. Samsung Galaxy Nexus Main Display Glass Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers or a spudger, lift the vibrator motor from its recess in the midframe.
      Ask FixBot
    7. Samsung Galaxy Nexus Main Display Glass Replacement: step 7, image 1 of 2 Samsung Galaxy Nexus Main Display Glass Replacement: step 7, image 2 of 2
      • Using tweezers, gently disconnect the antenna cable from its socket on the motherboard.
      Ask FixBot
    8. Samsung Galaxy Nexus Main Display Glass Replacement: step 8, image 1 of 2 Samsung Galaxy Nexus Main Display Glass Replacement: step 8, image 2 of 2
      • Use tweezers to pull the motherboard out of the phone.
      • Work carefully. Depending on the model, the underside of the motherboard may still have ribbon cables connecting it to the display assembly.
      Ask FixBot
    9. Samsung Galaxy Nexus Main Display Glass Replacement: step 9, image 1 of 3 Samsung Galaxy Nexus Main Display Glass Replacement: step 9, image 2 of 3 Samsung Galaxy Nexus Main Display Glass Replacement: step 9, image 3 of 3
      • Starting near the USB port, use your tweezers to pull the small daughterboard from the phone.
      Ask FixBot
13 other people completed this guide.
2 Guide Comments
with this guide , I found this repair easy to do. Thank you Tom G.
Thomas Giles - Reply Share
Deberían d3 poner los diagramas eléctricos para reparar gracias
manchadoshow - Reply Share
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 109
All Time: 21,447
