Samsung Galaxy Nexus Back Camera Lens Replacement
    1. Samsung Galaxy Nexus Back Camera Lens Replacement, Back of Phone: step 1, image 1 of 1
      • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
      Ask FixBot
    2. Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Back Cover: step 2, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Back Cover: step 2, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Back Cover: step 2, image 3 of 3
      • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
      Ask FixBot
    3. Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Battery: step 3, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Battery: step 3, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Battery: step 3, image 3 of 3
      • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
      • This is when a new battery will be inserted.
      Ask FixBot
    1. Samsung Galaxy Nexus Back Camera Lens Replacement, Motherboard: step 4, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement, Motherboard: step 4, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement, Motherboard: step 4, image 3 of 3
      • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
      Ask FixBot
    2. Samsung Galaxy Nexus Back Camera Lens Replacement: step 5, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 5, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 5, image 3 of 3
      • After removing the screws be sure to turn the phone right side up.
      • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
      • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
      Ask FixBot
    3. Samsung Galaxy Nexus Back Camera Lens Replacement, Removing Control Board: step 6, image 1 of 2 Samsung Galaxy Nexus Back Camera Lens Replacement, Removing Control Board: step 6, image 2 of 2
      • Unscrew 4.4mm with a PH #000 marked screw.
      Ask FixBot
    4. Samsung Galaxy Nexus Back Camera Lens Replacement: step 7, image 1 of 2 Samsung Galaxy Nexus Back Camera Lens Replacement: step 7, image 2 of 2
      • With the flat head screw driver pull up the blue connector.
      Ask FixBot
    5. Samsung Galaxy Nexus Back Camera Lens Replacement: step 8, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 8, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 8, image 3 of 3
      • With you finger or prying tool pull back bottom module.
      Ask FixBot
    6. Samsung Galaxy Nexus Back Camera Lens Replacement: step 9, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 9, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the internal battery using tweezers or your flat head screw driver.
      • There is glue at the bottom keeping battery and chassis stuck together.
      Ask FixBot
    7. Samsung Galaxy Nexus Back Camera Lens Replacement: step 10, image 1 of 2 Samsung Galaxy Nexus Back Camera Lens Replacement: step 10, image 2 of 2
      • Peel the display connector strip off the main circuit board using the tweezers.
      • Peel the USB connector strip off the main circuit board using the tweezers.
      Ask FixBot
    8. Samsung Galaxy Nexus Back Camera Lens Replacement: step 11, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 11, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 11, image 3 of 3
      • Remove the antenna using either your fingers or tweezers.
      Ask FixBot
    9. Samsung Galaxy Nexus Back Camera Lens Replacement: step 12, image 1 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 12, image 2 of 3 Samsung Galaxy Nexus Back Camera Lens Replacement: step 12, image 3 of 3
      • Using tweezers, pull the top circuit board off.
      • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
      Ask FixBot
    1. Samsung Galaxy Nexus Back Camera Lens Replacement, Back Camera Lens: step 13, image 1 of 2 Samsung Galaxy Nexus Back Camera Lens Replacement, Back Camera Lens: step 13, image 2 of 2
      Buy
      • Using tweezers pull out the back camera lens from the circuit board.
      Ask FixBot
4 other people completed this guide.
stewilli
1,500 Reputation
7 Guides authored
1 Guide Comment
Main picture of camera is off center.
Dan Brown - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 92
All Time: 1,924
