Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
    1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: step 1, image 1 of 1
      • Before beginning, make sure the phone is turned off.
      • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
      • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
      • Once the corner is released, slide your finger around the outside until the back cover releases.
      Ask FixBot
    2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 2, image 1 of 2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 2, image 2 of 2
      • Locate the battery.
      • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
      • Remove the battery.
      Ask FixBot
    3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 3, image 3 of 3
      • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
      • Using the pry tool, carefully pop the Digitizer cover off the device.
      • Use the pry tool to disconnect the digitizer
      Ask FixBot
    4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 4, image 1 of 2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 4, image 2 of 2
      • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
      • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
      • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
      • Once heated, gently pull the screen upward.
      • Make sure that the buttons are separating from the adhesive.
      Ask FixBot
    5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: step 5, image 1 of 1
      • Now, seperate the screen from the outside frame of the phone (the bezel).
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
I want to repair my phone
Monirul Islam - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 106
All Time: 1,946
