Samsung Galaxy Mega 2 Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
109
All Time:
2,040
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This repair guide will give a basic demonstration of how to remove the battery from a Galaxy Mega 2. The repair is fairly simple and does not take too much time. It involves removing the back cover and replacing the battery.
Tools
    1. Samsung Galaxy Mega 2 Battery Replacement, Battery: step 1, image 1 of 1
      • Before begining, make sure the phone is turned off.
      • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
      • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
      • Once you get the corner released, slide your finger around the outside until the back cover releases.
      Ask FixBot
    2. Samsung Galaxy Mega 2 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy Mega 2 Battery Replacement: step 2, image 2 of 2
      • Locate the battery.
      • Insert fingernail or plastic opening tool into the slot on bottom of the battery and gently lift up.
      • Remove the battery.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 109
All Time: 2,040
