Samsung Galaxy Light Motherboard Replacement
    1. Samsung Galaxy Light Motherboard Replacement, Remove Back Cover: step 1, image 1 of 1
      • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
      • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
      • Remove the back cover.
      Ask FixBot
    2. Samsung Galaxy Light Motherboard Replacement, Remove Battery: step 2, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
    1. Samsung Galaxy Light Motherboard Replacement, Unscrew Midframe: step 3, image 1 of 1
      • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
      Ask FixBot
    2. Samsung Galaxy Light Motherboard Replacement, Remove Midframe: step 4, image 1 of 1
      • Using the plastic opening tool, separate the midframe from the front panel of the device.
      • Remove the midframe.
      Ask FixBot
    3. Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: step 5, image 1 of 3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: step 5, image 2 of 3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: step 5, image 3 of 3
      • To detach the motherboard from the device:
      • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
      • Carefully lift the motherboard up and move it toward the left side of the device.
      • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
      Ask FixBot
7 other people completed this guide.
Diandra
216 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 103
All Time: 1,903
