Up to 20% off select tools
Samsung Galaxy Light Digitizer Replacement
Views: 6.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
112
All Time:
6,700
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to disassemble the device and replace the digitizer in a Samsung Galaxy Light (SGH-T399).
The Galaxy Light is a low-end phone that is significantly easier to service than onther Galaxy phones. The screen and digitizer are two separate items that are not directly attached to one another; it is perfectly possible to replace the digitizer without needing to touch the screen.
    1. Samsung Galaxy Light Digitizer Replacement, Remove Back Cover: step 1, image 1 of 1
      • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
      • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
      • Remove the back cover.
      Ask FixBot
    2. Samsung Galaxy Light Digitizer Replacement, Remove Battery: step 2, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
    1. Samsung Galaxy Light Digitizer Replacement, Unscrew Midframe: step 3, image 1 of 1
      • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
      Ask FixBot
    2. Samsung Galaxy Light Digitizer Replacement, Remove Midframe: step 4, image 1 of 1
      • Using the plastic opening tool, separate the midframe from the front panel of the device.
      • Remove the midframe.
      Ask FixBot
    3. Samsung Galaxy Light Digitizer Replacement, Detach Motherboard: step 5, image 1 of 3 Samsung Galaxy Light Digitizer Replacement, Detach Motherboard: step 5, image 2 of 3 Samsung Galaxy Light Digitizer Replacement, Detach Motherboard: step 5, image 3 of 3
      • To detach the motherboard from the device:
      • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
      • Carefully lift the motherboard up and move it toward the left side of the device.
      • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
      Ask FixBot
    1. Samsung Galaxy Light Digitizer Replacement, Remove the Audio/Vibrator Assembly: step 6, image 1 of 2 Samsung Galaxy Light Digitizer Replacement, Remove the Audio/Vibrator Assembly: step 6, image 2 of 2
      • Using a plastic opening tool, carefully remove the headphone jack (red)/earpiece (red)/vibrator (orange) assembly. This is removed as a single unit. Be particularly careful with the thin ribbon cables connecting them together as they can be easily torn.
      Ask FixBot
    2. Samsung Galaxy Light Digitizer Replacement, Remove the Audio/Vibrator Assembly Support: step 7, image 1 of 1
      • Using a plastic opening tool, remove the support piece.
      Ask FixBot
    3. Samsung Galaxy Light Digitizer Replacement, Disconnect and Remove the Digitizer Connector: step 8, image 1 of 1
      • Using a plastic opening tool, release the latch (it swings up towards the cable) and slide the digitizer connector free.
      • On the wide area of the cable (where the chip is), the cable is strongly glued to a small metal plate which is in turn strongly affixed to the back with heat-conducting adhesive. Loosen this cable from the back.
      • If you plan on reusing the digitizer be very careful when removing this as you can easily damage the cable. Use gentle applications of heat and a metal tool to pry between the metal plate and the back.
      Ask FixBot
    4. Samsung Galaxy Light Digitizer Replacement, Remove the Digitizer: step 9, image 1 of 2 Samsung Galaxy Light Digitizer Replacement, Remove the Digitizer: step 9, image 2 of 2
      • The area highlighted in red is where the digitizer cable feeds through a slot in the frame. If you plan on reusing the digitizer be very careful when detaching the digitizer from this area or you may damage the cable.
      • As you release the adhesive and pull the digitizer away from the frame, use guitar picks or cards to keep the adhesive from reattaching as it cools.
      • Work in sections starting from the top (near the Samsung logo). The adhesive is strong and thick all the way around. Apply even heat and pull the top edge away from the frame using plastic opening tools. The digitizer cable feeds through a slot in the frame.
      • Apply more heat to the sides, using the plastic opening tools to separate the digitizer from the frame. Be very careful not to push the tool too far inside so as not to damage the screen or smear adhesive on it.
      • Unlike other Samsung phones, there is no cable on the back of the two touch-sensitive buttons on either side of the home button.
      • Once the digitizer has been separated from the frame on all sides, remove it.
      Ask FixBot
    5. Samsung Galaxy Light Digitizer Replacement, Reinserting the Digitizer: step 10, image 1 of 1
      • Installation of a new digitizer is the reverse process. If the old digitizer was cracked, do a thorough inspection of the frame to remove any stray shards of glass before affixing the replacement digitizer or it will not sit right and can cause functional problems.
      Ask FixBot
8 other people completed this guide.
Author
with
Paul Goyette
490 Reputation
3 Guides authored
1 Guide Comment
It worked. Thank you ! :-)
nicu_vl - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 112
All Time: 6,700
