Samsung Galaxy J7 v Volume Button Replacement
    1. Samsung Galaxy J7 v Volume Button Replacement, Screen: step 1, image 1 of 1
      • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
      • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
      Ask FixBot
    2. Samsung Galaxy J7 v Volume Button Replacement: step 2, image 1 of 1
      • Gently slide the Jimmy tool around the entire perimeter of the phone.
      Ask FixBot
    3. Samsung Galaxy J7 v Volume Button Replacement: step 3, image 1 of 1
      • Be extra careful with the display's ribbon cables. They are fragile.
      • Carefully lift the display to remove it.
      Ask FixBot
    1. Samsung Galaxy J7 v Volume Button Replacement, Home button: step 4, image 1 of 1
      • Locate the socket of the home button.
      • Fit the metal spudger in between the socket and the home button.
      Ask FixBot
    2. Samsung Galaxy J7 v Volume Button Replacement: step 5, image 1 of 1
      • Take the metal spudger and slide it underneath the home button.
      • Lift up until the home button is removed from its socket.
      Ask FixBot
    1. Samsung Galaxy J7 v Volume Button Replacement, Volume Button: step 6, image 1 of 2 Samsung Galaxy J7 v Volume Button Replacement, Volume Button: step 6, image 2 of 2
      • Remove the screws around the home button and the screws above.
      Ask FixBot
    2. Samsung Galaxy J7 v Volume Button Replacement: step 7, image 1 of 1
      • Pull the screen away from the panel.
      Ask FixBot
    3. Samsung Galaxy J7 v Volume Button Replacement: step 8, image 1 of 2 Samsung Galaxy J7 v Volume Button Replacement: step 8, image 2 of 2
      • Remove all adjacent screws.
      Ask FixBot
    4. Samsung Galaxy J7 v Volume Button Replacement: step 9, image 1 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 9, image 2 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 9, image 3 of 3
      • Pop off panel from plastic hold.
      Ask FixBot
    5. Samsung Galaxy J7 v Volume Button Replacement: step 10, image 1 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 10, image 2 of 3 Samsung Galaxy J7 v Volume Button Replacement: step 10, image 3 of 3
      • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 44
All Time: 1,569
