Samsung Galaxy J7 Volume Button Replacement
    1. Samsung Galaxy J7 Volume Button Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy J7 Volume Button Replacement, Back Cover: step 1, image 2 of 2
      • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
      • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
      • Pry open the cover: Carefully work around the edges to remove the back cover completely
      • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
      Ask FixBot
    1. Samsung Galaxy J7 Volume Button Replacement, Volume Button: step 2, image 1 of 1
      • Once your device's back has been disassembled, grab the panel that has the volume buttons.
      Ask FixBot
    2. Samsung Galaxy J7 Volume Button Replacement: step 3, image 1 of 1
      • Turn the panel around and locate the volume button.
      Ask FixBot
    3. Samsung Galaxy J7 Volume Button Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Locate the rubber tabs and gently lift them up from their inserts with the tweezers.
      Ask FixBot
    4. Samsung Galaxy J7 Volume Button Replacement: step 5, image 1 of 1
      • Push button inward from the outside to remove.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 99
All Time: 2,577
