Samsung Galaxy J7 V Rear Camera Replacement
    1. Samsung Galaxy J7 V Rear Camera Replacement, Screen: step 1, image 1 of 1
      • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
      • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
      Ask FixBot
    2. Samsung Galaxy J7 V Rear Camera Replacement: step 2, image 1 of 1
      • Gently slide the Jimmy tool around the entire perimeter of the phone.
      Ask FixBot
    3. Samsung Galaxy J7 V Rear Camera Replacement: step 3, image 1 of 1
      • Be extra careful with the display's ribbon cables. They are fragile.
      • Carefully lift the display to remove it.
      Ask FixBot
    1. Samsung Galaxy J7 V Rear Camera Replacement, Home button: step 4, image 1 of 1
      • Locate the socket of the home button.
      • Fit the metal spudger in between the socket and the home button.
      Ask FixBot
    2. Samsung Galaxy J7 V Rear Camera Replacement: step 5, image 1 of 1
      • Take the metal spudger and slide it underneath the home button.
      • Lift up until the home button is removed from its socket.
      Ask FixBot
    1. Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: step 6, image 1 of 2 Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: step 6, image 2 of 2
      • Use the indent on the right side of the phone to lift up the backing
      • With the phone faced downwards, remove the backing of the case, lifting up from the right side
      Ask FixBot
    2. Samsung Galaxy J7 V Rear Camera Replacement, Remove the battery: step 7, image 1 of 1
      • Carefully remove the battery by lifting the bottom side, and then fully remove the battery
      Ask FixBot
    1. Samsung Galaxy J7 V Rear Camera Replacement, Motherboard: step 8, image 1 of 1
      • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Galaxy J7 V Rear Camera Replacement: step 9, image 1 of 1
      • Flip the phone to the back side where the battery was removed.
      • Apply pressure with your hands to pop the midframe off.
      Ask FixBot
    3. Samsung Galaxy J7 V Rear Camera Replacement: step 10, image 1 of 2 Samsung Galaxy J7 V Rear Camera Replacement: step 10, image 2 of 2
      • Flip the phone back over.
      • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
      • Place a few iFixit opening picks beneath the motherboard.
      • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
      • Lift the motherboard using the iFixit opening picks.
      Ask FixBot
    1. Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: step 11, image 1 of 3 Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: step 11, image 2 of 3 Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to detach the tab securing the rear camera.
      • Use your fingers to pull the camera away from the motherboard.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
goood
شكرا كتير لقد استفت من الموقع جدا واتمنى ان اواصل معرفه واطلاع على كل جديد
ageedaa11 - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,021
