Samsung Galaxy J7 Screen Assembly Replacement
    1. Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: step 1, image 2 of 2
      • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
      • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
      • Pry open the cover: Carefully work around the edges to remove the back cover completely
      • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
      Ask FixBot
    1. Samsung Galaxy J7 Screen Assembly Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy J7 Screen Assembly Replacement, Battery: step 2, image 2 of 2
      • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
      • Remove Battery: Gently pop out the edge and carefully pull out the battery.
      • Tip: Ensure the battery is disconnected from the motherboard before removing it.
      Ask FixBot
    1. Samsung Galaxy J7 Screen Assembly Replacement, Midframe: step 3, image 1 of 1
      • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
      Ask FixBot
    2. Samsung Galaxy J7 Screen Assembly Replacement: step 4, image 1 of 3 Samsung Galaxy J7 Screen Assembly Replacement: step 4, image 2 of 3 Samsung Galaxy J7 Screen Assembly Replacement: step 4, image 3 of 3
      • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
      • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
      Ask FixBot
    1. Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: step 5, image 1 of 2 Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: step 5, image 2 of 2
      • The speaker piece is lightly adhered. Use a plastic pry tool to gently lift it up and disconnect the cable.
      Ask FixBot
    2. Samsung Galaxy J7 Screen Assembly Replacement: step 6, image 1 of 2 Samsung Galaxy J7 Screen Assembly Replacement: step 6, image 2 of 2
      • Gently lift up the tab of the motor.
      • Remove the motor from the panel completely to disconnect it.
      • Removing the motor allows easier access to the screen assembly for replacement. Handle the motor and its connectors with care.
      Ask FixBot
    3. Samsung Galaxy J7 Screen Assembly Replacement: step 7, image 1 of 1
      • Reverse these steps with your new phone screen to replace it.
      • After reassembly, test the new screen for touch responsiveness and display quality before fully securing the device
      Ask FixBot
16 other people completed this guide.
1 Guide Comment
I replaced the broken screen....before I saw this. Now my phone will not turn on. what should I do? ruth.fnp@gmail.com
Ruth Thomas - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 71
All Time: 13,014
