Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
Pry open the cover: Carefully work around the edges to remove the back cover completely
Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
Remove Battery: Gently pop out the edge and carefully pull out the battery.
Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
2 other people completed this guide.
