Samsung Galaxy J6 Display Replacement
    1. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: step 1, image 1 of 3 Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: step 1, image 2 of 3 Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: step 1, image 3 of 3
      • I recommend wearing eye protection to avoid any inconvenience with glass fragments.
      • It is very important to heat the display on the side parts where the double-sided adhesive is well with a hairdryer or other so as to make it lose its adhesion and facilitate the operation of inserting the blade to lift it.
      • Insert the blade between the body and the glass and begin to separate the display from the body, I recommend starting from the top paying attention.
      • The flat connection connectors are located at the bottom.
      Ask FixBot
    2. Samsung Galaxy J6 Display Replacement, Lift up the display: step 2, image 1 of 2 Samsung Galaxy J6 Display Replacement, Lift up the display: step 2, image 2 of 2
      • Lift the display.
      Ask FixBot
    3. Samsung Galaxy J6 Display Replacement, Remove the display: step 3, image 1 of 3 Samsung Galaxy J6 Display Replacement, Remove the display: step 3, image 2 of 3 Samsung Galaxy J6 Display Replacement, Remove the display: step 3, image 3 of 3
      • Unplug the black plastic plug securing the display connector.
      • Unhook the display connector.
      • Remove the old display and place the new display.
      • Put some glue to attach the new display.
      Ask FixBot
55 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,380 Reputation
39 Guides authored
10 Guide Comments
f**k this adhesive!!
Thanks for this tutorial :)
NoCheatImPGM - Reply Share
Gli adesivi non aderiscono bene sono d’accordo,puoi provare con altro biadesivo 3M oppure con della colla idonea.
Smilzo - Reply Share
You mentioned nothing about disconnecting the battery. If the phone accidentally turns on in the middle of a display swap [with no way to turn it off, since there’s no display or digitser connected] you will blow an internal fuse, rendering the phone useless. Complete waste of time! You should have included that the battery be disconnected before attempting this.
Dot - Reply Share
Ciao ti ringrazio per la Puntualizzazione ed il buon consiglio.
io non ho mai avuto problemi nello scollegare i display perché il telefono è precedentemente spento e rimane spento fino a quando non scollego il connettore display.
se per sfortuna si dovesse toccare il tasto power (che comunque richiede una lunga pressione e non un semplice tocco ) si vedrebbe accendere il display o vibrare il telefono o accendersi i led. Quindi prima di scollegare lo spegnerei nuovamente.
non vedo il problema.
scollegare la batteria comporta una procedura analoga a togliere il display e quindi molto tempo in più ed accollarsi i rischi di rompere un componente posteriore per rimuoverlo,perdendo così impermeabilità se non si dispone di adesivo specifico per questa sostituzione.
Ciao e grazie della guida.
Quale modello di display e su quale sito consigli di comprarlo?
Danilo B. - Reply Share
Past 24 Hours: 7
Past 7 Days: 47
Past 30 Days: 233
All Time: 21,500
