Samsung Galaxy J5 2017 Display Replacement
  1. Samsung Galaxy J5 2017 Display Replacement, Display: step 1, image 1 of 2 Samsung Galaxy J5 2017 Display Replacement, Display: step 1, image 2 of 2
    • With a hair dryer, heat the glass well so that the adhesive glue can detach easily.
    • Use thin tools all over the profile and insert them between the plastic frame and the glass.
    • Do not insert the opening tools you are using between the aluminum and the plastic frame.
    Ask FixBot
  2. Samsung Galaxy J5 2017 Display Replacement: step 2, image 1 of 3 Samsung Galaxy J5 2017 Display Replacement: step 2, image 2 of 3 Samsung Galaxy J5 2017 Display Replacement: step 2, image 3 of 3
    • Lift the display from bottom to top where the flat and connector is connected.
    • Remove the black snap-on lid.
    • Unclip the connector.
    • Thoroughly clean the surfaces of glue residues and install the replacement display.
    Ask FixBot
To reassemble the device, follow these instructions in reverse order.
11 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,320 Reputation
39 Guides authored
3 Guide Comments
Questo Samsung ha davvero un sistema di sostituzione dello schermo molto pratico.
tanner85 - Reply Share
Certo ma se devi cambiare la batteria? Rompi lo schermo al 99%
Francesco Cogliano - Reply Share
¿Cómo puedo cambiar el puerto de carga de este dispositivo?
angel junior more bartolo - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 95
All Time: 10,108
