Samsung Galaxy J4 Charging Port Replacement
  1. Samsung Galaxy J4 Charging Port Replacement, Charging port: step 1, image 1 of 1
    • Switch off the phone.
    • Dissemble the phone
    • Open back cover and remove the battery
    • Remove the nuts with the aid of a screw driver.
  2. Samsung Galaxy J4 Charging Port Replacement: step 2, image 1 of 1
    • Remove the panel and recognize where the charging port is.
    • With the use of an opening tool remove the panel carefully.
  3. Samsung Galaxy J4 Charging Port Replacement: step 3, image 1 of 1
    • Removing the charging port with the use of a soldering iron or hot air
  4. Samsung Galaxy J4 Charging Port Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Get you new charging port and fix it legs on the panel.
    • Use hot air or soldering iron along side with a tweezers to remove the charging port.
  5. Samsung Galaxy J4 Charging Port Replacement: step 5, image 1 of 1
    • Making use of the hot air not soldering iron to fix the new charging port.
    • You can make use of a lead wire if the lead on the panel is not enough.
    • Boom you’re done replacing the charging port so place the panel back, screw the nut back and juice your phone.
9 other people completed this guide.
Obayemi Dorcas
277 Reputation
1 Guide authored
4 Guide Comments
Wow. Thanks for this contribution.
Aanuoluwapo Owoseeni - Reply Share
Incredible I believe this gonna help one replace charging port perfectly
Obayemi Dorcas - Reply Share
Que pasa si tengo un galaxy J4+(plus),en que cambia?, me pueden indicar?
Fabrizzio - Reply Share
no cambia nada
MATEO - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 121
All Time: 6,112
