Samsung Galaxy J3V Front Camera Replacement
    1. Samsung Galaxy J3V Front Camera Replacement, Front Camera: step 1, image 1 of 3 Samsung Galaxy J3V Front Camera Replacement, Front Camera: step 1, image 2 of 3 Samsung Galaxy J3V Front Camera Replacement, Front Camera: step 1, image 3 of 3
      • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
      Ask FixBot
    2. Samsung Galaxy J3V Front Camera Replacement: step 2, image 1 of 3 Samsung Galaxy J3V Front Camera Replacement: step 2, image 2 of 3 Samsung Galaxy J3V Front Camera Replacement: step 2, image 3 of 3
      • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
      Ask FixBot
    3. Samsung Galaxy J3V Front Camera Replacement: step 3, image 1 of 3 Samsung Galaxy J3V Front Camera Replacement: step 3, image 2 of 3 Samsung Galaxy J3V Front Camera Replacement: step 3, image 3 of 3
      • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
      • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
      Ask FixBot
    4. Samsung Galaxy J3V Front Camera Replacement: step 4, image 1 of 3 Samsung Galaxy J3V Front Camera Replacement: step 4, image 2 of 3 Samsung Galaxy J3V Front Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to flip tab of the front camera to remove it.
      Ask FixBot
Carry Corrales
792 Reputation
5 Guides authored
USF Tampa, Team S3-G3, Nance Fall 2017 Member of USF Tampa, Team S3-G3, Nance Fall 2017
USFT-NANCE-F17S3G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 102
All Time: 927
