Samsung Galaxy J3 Home Key Replacement
    1. Samsung Galaxy J3 Home Key Replacement, Home Key: step 1, image 1 of 1
      • Separate the back casing from the phone by carefully using your fingers to pry them apart.
      Ask FixBot
    2. Samsung Galaxy J3 Home Key Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    3. Samsung Galaxy J3 Home Key Replacement: step 3, image 1 of 1
      • Remove all ten screws by using a Phillips #000 screwdriver.
      Ask FixBot
    4. Samsung Galaxy J3 Home Key Replacement: step 4, image 1 of 1
      • Use the flat side of a spudger to remove the middle frame bezel.
      • Do not twist or wrench the spudger during this step as it will cause the screen to crack.
      Ask FixBot
    5. Samsung Galaxy J3 Home Key Replacement: step 5, image 1 of 1
      • Gently pull the glass up from the side of the phone and push the home button out.
      • When you pull the glass up, it will make a popping sound. This is normal.
      Ask FixBot
    6. Samsung Galaxy J3 Home Key Replacement: step 6, image 1 of 1
      • Replace the home button and press the glass back in place.
      Ask FixBot
3 other people completed this guide.
2 Guide Comments
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
Leonardo Sierra - Reply Share
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
Blins Cat - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 120
All Time: 3,709
