Samsung Galaxy J3 (2016) Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
Past 7 Days:
30
Past 30 Days:
140
All Time:
14,991
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Follow this guide to easily remove and replace the battery pack for your Samsung Galaxy J3.
Be sure to power off your phone before following this guide.
If your battery is swollen, take appropriate precautions.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Parts
Tools
  • Spudger
    4.9
    1. Samsung Galaxy J3 (2016) Battery Replacement, Rear Cover: step 1, image 1 of 2 Samsung Galaxy J3 (2016) Battery Replacement, Rear Cover: step 1, image 2 of 2
      • Insert a fingernail or the flat end of a spudger into the divot to the left of the rear-facing camera.
      • Gently pry the rear cover away from the phone until all the plastic clips holding the cover are released.
      Ask FixBot
    2. Samsung Galaxy J3 (2016) Battery Replacement: step 2, image 1 of 1
      • Remove the rear cover.
      • To reinstall the rear cover, align it to the back of the phone, and squeeze the perimeter of the phone to snap all the clips into place.
      Ask FixBot
    1. Samsung Galaxy J3 (2016) Battery Replacement, Battery: step 3, image 1 of 3 Samsung Galaxy J3 (2016) Battery Replacement, Battery: step 3, image 2 of 3 Samsung Galaxy J3 (2016) Battery Replacement, Battery: step 3, image 3 of 3
      • Insert a fingernail or the flat end of a spudger into the divot below the battery pack.
      • Pry the battery pack out of its recess.
      • If you use the spudger, do not push too hard or you will puncture the battery pack.
      • Remove the battery pack.
      Ask FixBot
Repair didn’t go as planned? Check out our Samsung Galaxy J3 (2016) Answers community for troubleshooting help.
9 other people completed this guide.
Arthur Shi
351,229 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
1 Guide Comment
Hmm I can't seem to get the back cover off my phone. This phone is a POS, always has been. It's slow, hard to use, and for almost 300.00 bucks it lasted about 2 years. What a racket these phone companies have going.
Mare Tomaski - Reply Share
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 140
All Time: 14,991
