Samsung Galaxy J1 Midframe Replacement
    1. Samsung Galaxy J1 Midframe Replacement, Midframe: step 1, image 1 of 1
      • Insert a finger nail or plastic opening tool between the back cover and the device.
      • Gently pry the rear cover off of the back of the phone.
      Ask FixBot
    2. Samsung Galaxy J1 Midframe Replacement: step 2, image 1 of 2 Samsung Galaxy J1 Midframe Replacement: step 2, image 2 of 2
      • Using a finger, pull the SIM card down out of its slot.
      • Remove the SIM card.
      • The pictured device is missing the SIM card and battery.
      Ask FixBot
    3. Samsung Galaxy J1 Midframe Replacement: step 3, image 1 of 1
      • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
      Ask FixBot
    4. Samsung Galaxy J1 Midframe Replacement: step 4, image 1 of 3 Samsung Galaxy J1 Midframe Replacement: step 4, image 2 of 3 Samsung Galaxy J1 Midframe Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool between the screen and the back of the device.
      • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
      • Gently pry the main assembly from the midframe of the device.
      • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
      Ask FixBot
7 other people completed this guide.
Sean Kramer
1,632 Reputation
6 Guides authored
USF Tampa, Team S5-G4, Eyestone Spring 2018 Member of USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 74
All Time: 2,886
