Samsung Galaxy Grand Prime Micro USB Port Replacement
    1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: step 1, image 3 of 3
      • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
      • Go around the edge of the back cover to completely remove it.
      Ask FixBot
    2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: step 2, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: step 2, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: step 2, image 3 of 3
      • Remove the old battery by lifting up on the thumb tab.
      • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
      Ask FixBot
    1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: step 3, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: step 3, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: step 3, image 3 of 3
      • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 4, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 4, image 2 of 2
      • Wedge the blue plastic opening tool in between the front and side panel.
      • Move the blue plastic opening tool around the edges between the front and side panel.
      Ask FixBot
    3. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 5, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 5, image 2 of 2
      • Make sure that you detach the mid-frame from the inside too.
      Ask FixBot
    1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: step 6, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: step 6, image 2 of 2
      • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
      Ask FixBot
    1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: step 7, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: step 7, image 2 of 2
      • Use the plastic opening tool to unhook the ribbon cable clip.
      Ask FixBot
    2. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 8, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Gently pull on the connector with the tweezers until the speaker comes off.
      Ask FixBot
    1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: step 9, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: step 9, image 2 of 2
      • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
      Ask FixBot
    2. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 10, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 10, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 10, image 3 of 3
      • Unhook the ribbon cable clip to the front camera.
      • Lift the motherboard up and out of the device.
      Ask FixBot
    3. Samsung Galaxy Grand Prime Micro USB Port Replacement: step 11, image 1 of 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: step 11, image 2 of 2
      • Remove the motherboard and unhook the ribbon cable clip to the back camera.
      Ask FixBot
    1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: step 12, image 1 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: step 12, image 2 of 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: step 12, image 3 of 3
      • Using a soldering iron to solder off the charging port.
      • Be careful soldering iron gets extremely hot.
      Ask FixBot
35 other people completed this guide.
Kyle Ruff
6,853 Reputation
5 Guides authored
USF Tampa, Team 17-3, Blackwell Winter 2016 Member of USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 123
All Time: 36,096
