Samsung Galaxy Gear Display Assembly Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
95
All Time:
2,129
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Should the screen need to be replaced, this guide will outline how to do so.
Parts
Tools
    1. Samsung Galaxy Gear Display Assembly Replacement, Display Housing: step 1, image 1 of 1
      • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
      • Be sure your device is turned off.
      Ask FixBot
    2. Samsung Galaxy Gear Display Assembly Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to separate the display housing from from the device.
      • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
      Ask FixBot
    3. Samsung Galaxy Gear Display Assembly Replacement: step 3, image 1 of 2 Samsung Galaxy Gear Display Assembly Replacement: step 3, image 2 of 2
      • Gently pry back the metal flap on top of the connector.
      • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
      Ask FixBot
    1. Samsung Galaxy Gear Display Assembly Replacement, Motherboard: step 4, image 1 of 2 Samsung Galaxy Gear Display Assembly Replacement, Motherboard: step 4, image 2 of 2
      • On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
      Ask FixBot
    2. Samsung Galaxy Gear Display Assembly Replacement: step 5, image 1 of 1
      • The motherboard is attached to the display using an adhesive
      • Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
      Ask FixBot
    3. Samsung Galaxy Gear Display Assembly Replacement: step 6, image 1 of 2 Samsung Galaxy Gear Display Assembly Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
      • Slowly pry up the motherboard from the display.
      Ask FixBot
    1. Samsung Galaxy Gear Display Assembly Replacement, Display Assembly: step 7, image 1 of 1
      • The display assembly is now separated and can be replaced
      Ask FixBot
2 other people completed this guide.
Joe
279 Reputation
2 Guides authored
Cal Poly, Team 1-9, Maness Spring 2016 Member of Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 95
All Time: 2,129
