Samsung Galaxy Express 3 Home Button Replacement
    1. Samsung Galaxy Express 3 Home Button Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Battery: step 1, image 2 of 2
      • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
      Ask FixBot
    2. Samsung Galaxy Express 3 Home Button Replacement: step 2, image 1 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 2, image 2 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 2, image 3 of 3
      • Once the cover is removed, locate the battery that reads "SAMSUNG."
      • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
      • Do not use a metal tool, as it can cause injury.
      Ask FixBot
    1. Samsung Galaxy Express 3 Home Button Replacement, Screen: step 3, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Screen: step 3, image 2 of 2
      • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
      Ask FixBot
    2. Samsung Galaxy Express 3 Home Button Replacement: step 4, image 1 of 1
      • Detach the screen connector.
      Ask FixBot
    3. Samsung Galaxy Express 3 Home Button Replacement: step 5, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement: step 5, image 2 of 2
      • Use a blow dryer or heating pad to heat up the screen.
      • Do not skip this step, as it may result in a broken screen and/or LCD.
      • This step loosens the glue holding the screen in place.
      Ask FixBot
    4. Samsung Galaxy Express 3 Home Button Replacement: step 6, image 1 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 6, image 2 of 3 Samsung Galaxy Express 3 Home Button Replacement: step 6, image 3 of 3
      • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
      • Do this slowly and carefully, as both parts can crack very easily.
      • Ensure your tool is plastic, as a metal tool can damage the screen easily.
      Ask FixBot
    1. Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): step 7, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): step 7, image 2 of 2
      • Use a plastic tool to remove back and/or recent tabs circuit buttons.
      • Use a plastic tool as a metal tool can be dangerous to the phone or you.
      Ask FixBot
    1. Samsung Galaxy Express 3 Home Button Replacement, Home Button: step 8, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement, Home Button: step 8, image 2 of 2
      • Use a #0 Phillips bit screwdriver to remove the four screws from the black, plastic piece surrounding the home button.
      • All four screws are the same size.
      Ask FixBot
    2. Samsung Galaxy Express 3 Home Button Replacement: step 9, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement: step 9, image 2 of 2
      • Using a sharp plastic tool such as a guitar pick or prying tool to pop up and remove the black, plastic piece.
      • Do not use a metal tool as it can be dangerous to you or the motherboard.
      Ask FixBot
    3. Samsung Galaxy Express 3 Home Button Replacement: step 10, image 1 of 2 Samsung Galaxy Express 3 Home Button Replacement: step 10, image 2 of 2
      • The white button will be connected to the black piece.
      • Slightly bend the black piece and gently push the white button until it pops out of the black, plastic piece.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 58
All Time: 902
