Up to 20% off select tools
Samsung Galaxy Core Screen Replacement
Views: 118K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
114
All Time:
118,287
Comments: 11
11 guide comments.
Go to guide comments
Completed: 90
90 people have marked this guide "completed." Will you be next?
Favorites: 50
50 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung Galaxy Core Screen Replacement, Screen: step 1, image 1 of 3 Samsung Galaxy Core Screen Replacement, Screen: step 1, image 2 of 3 Samsung Galaxy Core Screen Replacement, Screen: step 1, image 3 of 3
      • Flip the phone over and use your fingernail or an opening tool to remove the back cover.
      Ask FixBot
    2. Samsung Galaxy Core Screen Replacement: step 2, image 1 of 2 Samsung Galaxy Core Screen Replacement: step 2, image 2 of 2
      • Remove the battery.
      • If your phone has a SIM card or MicroSD card, remove them.
      Ask FixBot
    3. Samsung Galaxy Core Screen Replacement: step 3, image 1 of 1
      • Remove the 9 Phillips #00 screws from the mid-frame.
      Ask FixBot
    4. Samsung Galaxy Core Screen Replacement: step 4, image 1 of 2 Samsung Galaxy Core Screen Replacement: step 4, image 2 of 2
      • Use an opening pick to pry off the mid frame.
      Ask FixBot
    5. Samsung Galaxy Core Screen Replacement: step 5, image 1 of 2 Samsung Galaxy Core Screen Replacement: step 5, image 2 of 2
      • Disconnect the following ribbon cables from the motherboard:
      • The digitizer and LCD assembly.
      • Headphone Jack and Earpiece.
      • Daughter board flex cable.
      • Antenna connector.
      Ask FixBot
    6. Samsung Galaxy Core Screen Replacement: step 6, image 1 of 3 Samsung Galaxy Core Screen Replacement: step 6, image 2 of 3 Samsung Galaxy Core Screen Replacement: step 6, image 3 of 3
      • Use a plastic opening tool to remove the motherboard.
      Ask FixBot
    7. Samsung Galaxy Core Screen Replacement: step 7, image 1 of 3 Samsung Galaxy Core Screen Replacement: step 7, image 2 of 3 Samsung Galaxy Core Screen Replacement: step 7, image 3 of 3
      • Remove the single Phillips screw that secures the daughterboard.
      • Remove the daughterboard.
      • The flex cable is glued, so exercise extreme caution, as excessive force can damage the cable.
      Ask FixBot
    8. Samsung Galaxy Core Screen Replacement: step 8, image 1 of 3 Samsung Galaxy Core Screen Replacement: step 8, image 2 of 3 Samsung Galaxy Core Screen Replacement: step 8, image 3 of 3
      • Use an opening pick to remove the audio jack.
      Ask FixBot
    9. Samsung Galaxy Core Screen Replacement: step 9, image 1 of 2 Samsung Galaxy Core Screen Replacement: step 9, image 2 of 2
      • Disconnect the digitizer's ribbon cable.
      Ask FixBot
    10. Samsung Galaxy Core Screen Replacement: step 10, image 1 of 1
      • Push the earpiece mesh outwards to release it.
      Ask FixBot
    11. Samsung Galaxy Core Screen Replacement: step 11, image 1 of 1
      • Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
      • Use an opening pick to break up the glue around the edges of the digitizer.
      • You may apply more heat if needed.
      • Remove the digitizer and any broken glass.
      Ask FixBot
90 other people completed this guide.
Author
with
ivan coene
3,006 Reputation
2 Guides authored
11 Guide Comments
yes, but where can I buy the screen replacement?
Roxannie - Reply Share
I bought it on Ebay...
ivan coene - Reply Share
Comment root galaxy core prime g361f android 5.1.1
soulaemen - Reply Share
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Thomas McGuigan - Reply Share
Nor do they show how the new digitizer plugs in...
chris smith - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 114
All Time: 118,287
