Samsung Galaxy Core Prime Screen Replacement
    1. Samsung Galaxy Core Prime Screen Replacement, Battery: step 1, image 1 of 1
      • Turn the smartphone off by using the power button on the right-hand side.
      Ask FixBot
    2. Samsung Galaxy Core Prime Screen Replacement: step 2, image 1 of 1
      • Turn the smartphone over so that the rear camera is face up.
      Ask FixBot
    3. Samsung Galaxy Core Prime Screen Replacement: step 3, image 1 of 1
      • Use your fingernail or a flat tool to lift the back cover.
      Ask FixBot
    4. Samsung Galaxy Core Prime Screen Replacement: step 4, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 4, image 2 of 2
      • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
      Ask FixBot
    5. Samsung Galaxy Core Prime Screen Replacement: step 5, image 1 of 1
      • Use your fingernail or a flat tool to lift the battery out.
      Ask FixBot
    1. Samsung Galaxy Core Prime Screen Replacement, Screen: step 6, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement, Screen: step 6, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
      Ask FixBot
    2. Samsung Galaxy Core Prime Screen Replacement: step 7, image 1 of 1
      • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
      • Take care when using these heat tools.
      Ask FixBot
    3. Samsung Galaxy Core Prime Screen Replacement: step 8, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 8, image 2 of 2
      Tool used on this step:
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    4. Samsung Galaxy Core Prime Screen Replacement: step 9, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 9, image 2 of 2
      Buy
      • Use tweezers to disconnect the power ribbon from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Core Prime Screen Replacement: step 10, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 10, image 2 of 2
      • Use tweezers or your hand to remove the audiojack.
      Ask FixBot
    6. Samsung Galaxy Core Prime Screen Replacement: step 11, image 1 of 1
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    7. Samsung Galaxy Core Prime Screen Replacement: step 12, image 1 of 1
      iFixit Opening Tool
      $1.99
      Buy
      • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
      Ask FixBot
    8. Samsung Galaxy Core Prime Screen Replacement: step 13, image 1 of 3 Samsung Galaxy Core Prime Screen Replacement: step 13, image 2 of 3 Samsung Galaxy Core Prime Screen Replacement: step 13, image 3 of 3
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    9. Samsung Galaxy Core Prime Screen Replacement: step 14, image 1 of 2 Samsung Galaxy Core Prime Screen Replacement: step 14, image 2 of 2
      • Use tweezers to disconnect the digitizer.
      Ask FixBot
8 other people completed this guide.
Cody Coombs
269 Reputation
1 Guide authored
1 Guide Comment
What if the phone does not come back on after assembly
nfl.ny.la.313 - Reply Share
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 92
All Time: 3,494
