Up to 20% off select tools
Samsung Galaxy Core Display Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
109
All Time:
2,128
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Samsung Galaxy Core Display Replacement, Display: step 1, image 1 of 2 Samsung Galaxy Core Display Replacement, Display: step 1, image 2 of 2
      • Turn the phone off
      • Remove the back cover
      • Extract battery
      Ask FixBot
    2. Samsung Galaxy Core Display Replacement: step 2, image 1 of 1
      • Remove the 9 screws
      Ask FixBot
    3. Samsung Galaxy Core Display Replacement: step 3, image 1 of 1
      • Remove the central frame to access the motherboard, help yourself with a thin tool
      • Remove the black screw that secures the lower motherboard
      Ask FixBot
    4. Samsung Galaxy Core Display Replacement: step 4, image 1 of 3 Samsung Galaxy Core Display Replacement: step 4, image 2 of 3 Samsung Galaxy Core Display Replacement: step 4, image 3 of 3
      • Unclip the 3 connectors
      • Disconnect the connection cable of the 2 motherboards
      • With a flat instrument, help yourself to unhook the motherboard
      Ask FixBot
    5. Samsung Galaxy Core Display Replacement: step 5, image 1 of 3 Samsung Galaxy Core Display Replacement: step 5, image 2 of 3 Samsung Galaxy Core Display Replacement: step 5, image 3 of 3
      • Remove top motherboard
      • Remove Speaker
      • Remove the lower motherboard with the help of a hot air hairdryer to help it detach from the adhesive
      Ask FixBot
    6. Samsung Galaxy Core Display Replacement: step 6, image 1 of 2 Samsung Galaxy Core Display Replacement: step 6, image 2 of 2
      • If the touch screen glass is broken, use tape to avoid injury
      • Disconnect the TouchScreen connector
      Ask FixBot
    7. Samsung Galaxy Core Display Replacement: step 7, image 1 of 1
      • Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
      • Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
      Ask FixBot
    8. Samsung Galaxy Core Display Replacement: step 8, image 1 of 3 Samsung Galaxy Core Display Replacement: step 8, image 2 of 3 Samsung Galaxy Core Display Replacement: step 8, image 3 of 3
      • Remove the display with thin tools, using heat to detach the fixing adhesive
      Ask FixBot
To Reassemble your device, Follow these instruction reverse order.
3 other people completed this guide.
Special thanks to these translators:
it en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Smilzo
12,407 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 109
All Time: 2,128
