Up to 20% off select tools
Samsung Galaxy Camera Screen Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
104
All Time:
1,758
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
The Samsung Galaxy Camera has many wonderful features for its time like a 21x zoom and 1080p resolution. However, none of these features matter if the device can not be used. The screen is necessary to operate the Samsung Galaxy Camera since taking photos and recording videos are all done by interacting with the screen. Repairing the broken screen is vital to being able to properly utilize the device.
Some reasons the screen may need replacement are due to cracks or due to a malfunctioning display. This guide will help in the case that the screen itself is the issue. If the device was damaged through external force or exposure, there is the possibility of issues being caused by internal damage, such as a faulty motherboard. That guide can be found here. Use the troubleshooting page to review possible issues and identify what repair seems most applicable.
This guide has a moderate difficulty because it requires a decent amount of disassembly and handling of internal parts. Beyond that, there is not any specialist knowledge required. Be mindful when performing any prying to avoid accidentally damaging the device. Make sure to disconnect the device from any power sources before starting.
    1. Samsung Galaxy Camera Screen Replacement, Screen: step 1, image 1 of 1
      • Begin removing the 3/16" screws for the device.
      Ask FixBot
    2. Samsung Galaxy Camera Screen Replacement: step 2, image 1 of 1
      • Turn the device and remove the additional 3/16" screws.
      Ask FixBot
    3. Samsung Galaxy Camera Screen Replacement: step 3, image 1 of 1
      • Turn the device and remove the additional 3/16" screw.
      Ask FixBot
    4. Samsung Galaxy Camera Screen Replacement: step 4, image 1 of 3 Samsung Galaxy Camera Screen Replacement: step 4, image 2 of 3 Samsung Galaxy Camera Screen Replacement: step 4, image 3 of 3
      • Take the white cover plate off.
      Ask FixBot
    5. Samsung Galaxy Camera Screen Replacement: step 5, image 1 of 1
      • Using the plastic opening tools, pry open the camera from the bottom.
      • This may require a moderate use of force because of the sealing glue.
      Ask FixBot
    6. Samsung Galaxy Camera Screen Replacement: step 6, image 1 of 1
      • Gently pull the connector away from the motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
7 other people completed this guide.
Author
with
Richard Hicks
1,280 Reputation
4 Guides authored
USF Tampa, Team 1-3, Sullivan Winter 2015 Member of USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Members
48 Guides authored
1 Guide Comment
Fix cannot connect to camera error
Robert Spencer - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 104
All Time: 1,758
