Up to 20% off select tools
Samsung Galaxy Camera Capture button Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
133
All Time:
4,158
Comments: 12
6 comments on steps, 6 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 35 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung Galaxy Camera Capture button Replacement, Screen: step 1, image 1 of 1
      • Begin removing the 3/16" screws for the device.
      Ask FixBot
    2. Samsung Galaxy Camera Capture button Replacement: step 2, image 1 of 1
      • Turn the device and remove the additional 3/16" screws.
      Ask FixBot
    3. Samsung Galaxy Camera Capture button Replacement: step 3, image 1 of 1
      • Turn the device and remove the additional 3/16" screw.
      Ask FixBot
    4. Samsung Galaxy Camera Capture button Replacement: step 4, image 1 of 3 Samsung Galaxy Camera Capture button Replacement: step 4, image 2 of 3 Samsung Galaxy Camera Capture button Replacement: step 4, image 3 of 3
      • Take the white cover plate off.
      Ask FixBot
    5. Samsung Galaxy Camera Capture button Replacement: step 5, image 1 of 1
      • Using the plastic opening tools, pry open the camera from the bottom.
      • This may require a moderate use of force because of the sealing glue.
      Ask FixBot
    6. Samsung Galaxy Camera Capture button Replacement: step 6, image 1 of 1
      • Gently pull the connector away from the motherboard.
      Ask FixBot
    1. Samsung Galaxy Camera Capture button Replacement, Lens and Motherboard: step 7, image 1 of 1
      • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
      Ask FixBot
    2. Samsung Galaxy Camera Capture button Replacement: step 8, image 1 of 1
      • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
      Ask FixBot
    3. Samsung Galaxy Camera Capture button Replacement: step 9, image 1 of 1
      • Pull these connectors away from motherboard.
      Ask FixBot
    4. Samsung Galaxy Camera Capture button Replacement: step 10, image 1 of 1
      • Lift the motherboard and lens out of the case.
      Ask FixBot
    1. Samsung Galaxy Camera Capture button Replacement, Unscrew: step 11, image 1 of 1
      • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
      Ask FixBot
    2. Samsung Galaxy Camera Capture button Replacement: step 12, image 1 of 1
      • Unscrew the 3 5/32" screws that cover the battery plate.
      Ask FixBot
    3. Samsung Galaxy Camera Capture button Replacement: step 13, image 1 of 1
      • The black plates on the other side can be removed after these screws.
      Ask FixBot
    4. Samsung Galaxy Camera Capture button Replacement: step 14, image 1 of 1
      • Pull the flash and battery case out of the device.
      Ask FixBot
    1. Samsung Galaxy Camera Capture button Replacement, Capture button: step 15, image 1 of 1
      • Unscrew the 2 5/32" screws on the grey plate.
      Ask FixBot
    2. Samsung Galaxy Camera Capture button Replacement: step 16, image 1 of 1
      • Pull the plate aside and unscrew 2 1/8" screws on the button.
      Ask FixBot
    3. Samsung Galaxy Camera Capture button Replacement: step 17, image 1 of 1
      • The Capture button can now be removed.
      Ask FixBot
10 other people completed this guide.
Author
with
Richard Hicks
1,280 Reputation
4 Guides authored
USF Tampa, Team 1-3, Sullivan Winter 2015 Member of USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Members
48 Guides authored
6 Guide Comments
Thank you very much for these instructions - they enabled me to fix the camera after four repair places refused to.
(the two screws holding the shutter button in place had come loose - the button had fallen off and the loose screws inside were interfering with the zoom switch, sending the camera always to safe mode)
A couple of things: It is not necessary to remove the black screws at step 8. They hold something in place in the lens assembly, but don't prevent you from moving to step 10. Also, it is not necessary to remove the screws at step 11 - only the leftmost one in the image. If you are careful of the wires, the battery case can be folded back giving adequate access to the shutter assembly.
Also - when reassembling, be careful at step 17 that the zoom lever is positioned to be engaged with (hooked over) the lever on the brown circuit board.
danridleyellis - Reply Share
It's a good and detailed instruction, but it also has mistakes (see my comments to steps 8, 11 and 15).
NOVOMOTION J. H. - Reply Share
Thank You so much for the help! I would have never been able to replace the button without these instructions. You are a lifesaver.
Karen Rose - Reply Share
Dis assembly has been educational and all ,but where do I get my new button???????
Paul Rice - Reply Share
I realize the I wouldn't have been able to get this camara apart without the instructions. Very helpful and I do thank you Mr. Hicks. But I didn't want to take it apart. I want to fix it… and put it back together….and use it…perhaps just maybe take a photo or two. So please may I ask for information on obtaining a replacement capture/ zoom button assembly/ parts?????
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 133
All Time: 4,158
