Up to 20% off select tools
Samsung Galaxy Camera Camera Flash Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
108
All Time:
1,629
Comments: 4
4 comments on steps.
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung Galaxy Camera Camera Flash Replacement, Screen: step 1, image 1 of 1
      • Begin removing the 3/16" screws for the device.
      Ask FixBot
    2. Samsung Galaxy Camera Camera Flash Replacement: step 2, image 1 of 1
      • Turn the device and remove the additional 3/16" screws.
      Ask FixBot
    3. Samsung Galaxy Camera Camera Flash Replacement: step 3, image 1 of 1
      • Turn the device and remove the additional 3/16" screw.
      Ask FixBot
    4. Samsung Galaxy Camera Camera Flash Replacement: step 4, image 1 of 3 Samsung Galaxy Camera Camera Flash Replacement: step 4, image 2 of 3 Samsung Galaxy Camera Camera Flash Replacement: step 4, image 3 of 3
      • Take the white cover plate off.
      Ask FixBot
    5. Samsung Galaxy Camera Camera Flash Replacement: step 5, image 1 of 1
      • Using the plastic opening tools, pry open the camera from the bottom.
      • This may require a moderate use of force because of the sealing glue.
      Ask FixBot
    6. Samsung Galaxy Camera Camera Flash Replacement: step 6, image 1 of 1
      • Gently pull the connector away from the motherboard.
      Ask FixBot
    1. Samsung Galaxy Camera Camera Flash Replacement, Lens and Motherboard: step 7, image 1 of 1
      • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
      Ask FixBot
    2. Samsung Galaxy Camera Camera Flash Replacement: step 8, image 1 of 1
      • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
      Ask FixBot
    3. Samsung Galaxy Camera Camera Flash Replacement: step 9, image 1 of 1
      • Pull these connectors away from motherboard.
      Ask FixBot
    4. Samsung Galaxy Camera Camera Flash Replacement: step 10, image 1 of 1
      • Lift the motherboard and lens out of the case.
      Ask FixBot
    1. Samsung Galaxy Camera Camera Flash Replacement, Unscrew: step 11, image 1 of 1
      • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
      Ask FixBot
    2. Samsung Galaxy Camera Camera Flash Replacement: step 12, image 1 of 1
      • Unscrew the 3 5/32" screws that cover the battery plate.
      Ask FixBot
    3. Samsung Galaxy Camera Camera Flash Replacement: step 13, image 1 of 1
      • The black plates on the other side can be removed after these screws.
      Ask FixBot
    4. Samsung Galaxy Camera Camera Flash Replacement: step 14, image 1 of 1
      • Pull the flash and battery case out of the device.
      Ask FixBot
13 other people completed this guide.
Author
with
Richard Hicks
1,280 Reputation
4 Guides authored
USF Tampa, Team 1-3, Sullivan Winter 2015 Member of USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 108
All Time: 1,629
