Samsung Galaxy Camera 2 Lens Assembly Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
113
All Time:
6,168
Comments: 10
3 comments on steps, 7 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the lens of the camera. This guide comes in handy if the "camera" part of your Android camera is malfunctioning. Anything from the glass lens being cracked to the zoom not extending can be fixed by replacing the lens mechanism. Make sure to remove the battery before attempting any repairs!
Tools
    1. Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen: step 1, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen: step 1, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen: step 1, image 3 of 3
      • While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
      • Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
      Ask FixBot
    2. Samsung Galaxy Camera 2 Lens Assembly Replacement: step 2, image 1 of 1
      • Use the screwdriver to remove screws listed in step 2. There are a total of six 4mm screws.
      Ask FixBot
    3. Samsung Galaxy Camera 2 Lens Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 3, image 3 of 3
      • With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
      • Once this side is free, gently work your way along the edge, all the way around the camera body.
      Ask FixBot
    4. Samsung Galaxy Camera 2 Lens Assembly Replacement: step 4, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 4, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 4, image 3 of 3
      • With the screen freed, gently lay the camera on its face, so that the battery compartment faces up. Use both hands to lift the screen up and away.
      • The screen is still attached to the motherboard by a ribbon cable. Be Gentle as it's very fragile.
      Ask FixBot
    5. Samsung Galaxy Camera 2 Lens Assembly Replacement: step 5, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 5, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 5, image 3 of 3
      • With the screen separated from the main chassis, use the plastic opening tool to gently pry the edge of the ribbon cable connector from the motherboard.
      Ask FixBot
    6. Samsung Galaxy Camera 2 Lens Assembly Replacement, Screen Separated: step 6, image 1 of 1
      • Now the screen is removed.
      • Set the body aside in a safe place.
      Ask FixBot
    1. Samsung Galaxy Camera 2 Lens Assembly Replacement, Lens Assembly: step 7, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement, Lens Assembly: step 7, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement, Lens Assembly: step 7, image 3 of 3
      • After removing the screen and battery to access to the inside of the camera, take note of the two main assemblies inside-- the lens apparatus and the main motherboard. The lens assembly is on the left hand side.
      • There are three small silver screws (4mm PH00) to remove.
      Ask FixBot
    2. Samsung Galaxy Camera 2 Lens Assembly Replacement: step 8, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 8, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • With the three screws removed, take note of the two ribbon cables connecting the lens assembly to the main motherboard.
      • Use the tweezers to remove the two green strips of tape protecting the connectors.
      • Use the plastic opening tool to release the black clips locking in the ribbon cables, then use the tweezers to gently pull the ribbon cables away from the main motherboard.
      Ask FixBot
    3. Samsung Galaxy Camera 2 Lens Assembly Replacement: step 9, image 1 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 9, image 2 of 3 Samsung Galaxy Camera 2 Lens Assembly Replacement: step 9, image 3 of 3
      • Now that the screws and ribbon cables have been removed, gently pull the lens assembly up from the the camera and remove it.
      Ask FixBot
11 other people completed this guide.
Timothy Proto
838 Reputation
3 Guides authored
USF Tampa, Team 14-5, Lacy Spring 2016 Member of USF Tampa, Team 14-5, Lacy Spring 2016
USFT-LACY-S16S14G5
3 Members
72 Guides authored
7 Guide Comments
I followed the instructions to replace the lens. However, the camera will not work. Error message says Warning Camera Failed. What went wrong?
Gary Mason - Reply Share
You have a Mother Board Problem
janotrek - Reply Share
i have dust inside the lenses , how do i open the lens only?
Myra Arcadia - Reply Share
If you don't place the ribbon on the lenses right you can get that error too
Mark brad - Reply Share
The instructions are fine, as far as they go, which isn't nearly far enough. A much more thorough tutorial - with several key steps that are missing from these instructions, can be found at https://www.youtube.com/watch?v=qpExoJua.... I wouldn't have been able to complete the installation correctly without this helpful video.
David - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 113
All Time: 6,168
