Samsung Galaxy Buds Plus Case Battery Replacement
  1. Samsung Galaxy Buds Plus Case Battery Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Buds Plus Case Battery Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Buds Plus Case Battery Replacement, Battery: step 1, image 3 of 3
    • Before you proceed, discharge your battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Open the case and remove both of the earbuds.
    Ask FixBot
  2. Samsung Galaxy Buds Plus Case Battery Replacement: step 2, image 1 of 3 Samsung Galaxy Buds Plus Case Battery Replacement: step 2, image 2 of 3 Samsung Galaxy Buds Plus Case Battery Replacement: step 2, image 3 of 3
    • Insert an opening tool between the interior plastic cover and the exterior case.
    • This may take multiple tries at different contact angles.
    • Once inserted, pry up to begin separating the interior cover from the exterior case.
    • Move the opening tool around the edge until all of the clips holding the interior cover in place are released.
    • Remove and place the interior cover to the side.
    Ask FixBot
  3. Samsung Galaxy Buds Plus Case Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 3, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws holding the case's lid and hinge.
    • All of the screws in this guide share the same head and are the same length.
    Ask FixBot
  4. Samsung Galaxy Buds Plus Case Battery Replacement: step 4, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 4, image 2 of 2
    • Flip the case over to the back.
    • Use a nylon spudger to pry and pop out the hinge from the body of the case.
    Ask FixBot
  5. Samsung Galaxy Buds Plus Case Battery Replacement: step 5, image 1 of 3 Samsung Galaxy Buds Plus Case Battery Replacement: step 5, image 2 of 3 Samsung Galaxy Buds Plus Case Battery Replacement: step 5, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the two screws on either side of the USB-C port.
    • Remove the metal shielding from the USB-C port.
    • Remove the final Phillips #000 screw securing the motherboard and battery to the case.
    Ask FixBot
  6. Samsung Galaxy Buds Plus Case Battery Replacement: step 6, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 6, image 2 of 2
    • Firmly hold the case in one hand and pull out the motherboard and battery from the case using two fingers.
    Ask FixBot
  7. Samsung Galaxy Buds Plus Case Battery Replacement: step 7, image 1 of 3 Samsung Galaxy Buds Plus Case Battery Replacement: step 7, image 2 of 3 Samsung Galaxy Buds Plus Case Battery Replacement: step 7, image 3 of 3
    • Identify the LED indicator and gently detach it from the plastic housing of the motherboard using the spudger.
    Ask FixBot
  8. Samsung Galaxy Buds Plus Case Battery Replacement: step 8, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 8, image 2 of 2
    • Flip the board over and peel off the wireless charging coil.
    • Be careful not to break the two thin wires connecting the charging coil to the motherboard.
    Ask FixBot
  9. Samsung Galaxy Buds Plus Case Battery Replacement: step 9, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 9, image 2 of 2
    • Separate the motherboard from the battery and plastic housing.
    Ask FixBot
  10. Samsung Galaxy Buds Plus Case Battery Replacement: step 10, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 10, image 2 of 2
    • Identify the positive and negative terminal pads that are connected to the battery.
    • The corner that is diagonal to the correct pads should not have any pads.
    • Use the spudger to detach the pads from the plastic housing.
    Ask FixBot
  11. Samsung Galaxy Buds Plus Case Battery Replacement: step 11, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 11, image 2 of 2
    • Use a heat gun or hair dryer on medium to low heat to soften the battery adhesive for 20-30 seconds.
    • Insert the spudger between the battery and the plastic housing and gently pry up until the battery is free.
    • Overheating or puncturing the battery may cause it to ignite.
    Ask FixBot
  12. Samsung Galaxy Buds Plus Case Battery Replacement: step 12, image 1 of 2 Samsung Galaxy Buds Plus Case Battery Replacement: step 12, image 2 of 2
    • Remove the battery from the plastic housing.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 other people completed this guide.
Darius Nguyen
259 Reputation
1 Guide authored
UC Davis, Team 1-5, Morris Fall 2024 Member of UC Davis, Team 1-5, Morris Fall 2024
UCD-MORRIS-F24S1G5
3 Members
1 Guide authored
4 Guide Comments
This is an excelent guide. Followed it to the T and I would say there's nothing else to add. Thank you for it!
DMP - Reply Share
How to fine samsung galaxy airduds lpus case battery
PREM LOVE - Reply Share
Hey there! Here is an Amazon link where you can order the battery along with some tools too: https://a.co/d/8NPdu7n
Darius Nguyen - Reply Share
Superb guide. Followed it step by step to disassemble and reassemble, was a breeze. Need to take note of the small pair of square and trapezoid magnets position before putting all parts back. Battery replacement price is around RM26.90 a piece in Malaysia (Shopee discounted price)
zul broq - Reply Share
Past 24 Hours: 9
Past 7 Days: 59
Past 30 Days: 266
All Time: 5,354
