Samsung Galaxy Book Pro 360 15" SSD Replacement
Views: 8.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
68
Past 30 Days:
209
All Time:
8,146
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace one or both of the SSDs in your Galaxy Book Pro 360 15" laptop.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Access the rubber feet: step 1, image 1 of 2 Samsung Galaxy Book Pro 360 15" SSD Replacement, Access the rubber feet: step 1, image 2 of 2
      • Before you begin, shut down your laptop and unplug it.
      • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
      Ask FixBot
    2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: step 2, image 1 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: step 2, image 2 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Insert an opening pick between the rear case and the rubber foot.
      • Pry up with the pick and dislodge the foot from the rear case.
      • Use tweezers or your fingers to remove the rubber foot.
      • Repeat this process on the remaining rubber feet.
      • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
      • To reinstall a rubber foot, align it over the recess and push down until it's secured.
      Ask FixBot
    1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the rear case: step 3, image 1 of 2 Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the rear case: step 3, image 2 of 2
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
      Ask FixBot
    2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: step 4, image 1 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: step 4, image 2 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
      • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
      • This may take significant force and multiple tries.
      • Insert an opening pick into the gap you created.
      Ask FixBot
    3. Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: step 5, image 1 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: step 5, image 2 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: step 5, image 3 of 3
      • Slide the opening pick along the bottom edge to release the clips securing the rear case.
      • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
      Ask FixBot
    4. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: step 6, image 1 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: step 6, image 2 of 3 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: step 6, image 3 of 3
      • Lift the rear case up and away from the laptop and remove it.
      • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
      Ask FixBot
    1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the battery connector's tape: step 7, image 1 of 2 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the battery connector's tape: step 7, image 2 of 2
      Buy
      • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
      • Set the tape aside. You'll reuse it during reassembly.
      Ask FixBot
    2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Book Pro 360 15" SSD Replacement, Disconnect the battery: step 8, image 2 of 2
      • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
      • Gently pry up and disconnect the battery connector from its socket.
      Ask FixBot
    1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the SSD: step 9, image 1 of 2 Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the SSD: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the 3.5 mm screw securing the left SSD.
      Ask FixBot
    2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the SSD: step 10, image 1 of 2 Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the SSD: step 10, image 2 of 2
      • Pull the left SSD out of its socket and remove it.
      • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
      Ask FixBot
    3. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the right SSD: step 11, image 1 of 1
      • If you have a right SSD installed, repeat the removal procedure on it.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
4 other people completed this guide.
Spencer Day
206,507 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
1 Guide Comment
Hello! The Galaxy Book3 360 not the Pro version, also has two coolers? Or only one?
Erick Giacomazza - Reply Share
Past 24 Hours: 6
Past 7 Days: 68
Past 30 Days: 209
All Time: 8,146
