Samsung Galaxy Book Pro 15" Fan Replacement
    1. Samsung Galaxy Book Pro 15" Fan Replacement, Remove the rubber feet: step 1, image 1 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Remove the rubber feet: step 1, image 2 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Remove the rubber feet: step 1, image 3 of 3
      • Before you begin, power down your laptop and unplug it.
      • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
      • Insert an opening pick between the rubber foot and the rear case.
      • Pry up with the opening pick to release the clips securing the foot.
      • Remove the foot.
      • Repeat this procedure for the three remaining feet.
      • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
      Ask FixBot
    1. Samsung Galaxy Book Pro 15" Fan Replacement, Unfasten the rear case: step 2, image 1 of 2 Samsung Galaxy Book Pro 15" Fan Replacement, Unfasten the rear case: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
      Ask FixBot
    2. Samsung Galaxy Book Pro 15" Fan Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy Book Pro 15" Fan Replacement, Release the clips: step 4, image 1 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Release the clips: step 4, image 2 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Release the clips: step 4, image 3 of 3
      • Slide the pick along the bottom edge of the rear case to release its plastic clips.
      • Repeat this process for the left and right edges, but stop before reaching the top edge.
      Ask FixBot
    4. Samsung Galaxy Book Pro 15" Fan Replacement, Remove the rear case: step 5, image 1 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Remove the rear case: step 5, image 2 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Remove the rear case: step 5, image 3 of 3
      • The top edge of the rear case is lightly adhered to the frame.
      • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
      • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
      • Remove the rear case.
      • During reassembly, perform the following:
      • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
      • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
      • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
      Ask FixBot
    1. Samsung Galaxy Book Pro 15" Fan Replacement, Disconnect the battery: step 6, image 1 of 2 Samsung Galaxy Book Pro 15" Fan Replacement, Disconnect the battery: step 6, image 2 of 2
      • Insert a spudger between the frame and the bottom of the battery cable connector.
      • Pry up and disconnect the battery cable connector.
      Ask FixBot
    1. Samsung Galaxy Book Pro 15" Fan Replacement, Disconnect the fan: step 7, image 1 of 2 Samsung Galaxy Book Pro 15" Fan Replacement, Disconnect the fan: step 7, image 2 of 2
      Ask FixBot
    2. Samsung Galaxy Book Pro 15" Fan Replacement: step 8, image 1 of 2 Samsung Galaxy Book Pro 15" Fan Replacement: step 8, image 2 of 2
      • Disconnect the fan cable by sliding it out from its socket on the motherboard.
      Ask FixBot
    3. Samsung Galaxy Book Pro 15" Fan Replacement, Unfasten the fan: step 9, image 1 of 2 Samsung Galaxy Book Pro 15" Fan Replacement, Unfasten the fan: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the fan.
      Ask FixBot
    4. Samsung Galaxy Book Pro 15" Fan Replacement, Remove the fan: step 10, image 1 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Remove the fan: step 10, image 2 of 3 Samsung Galaxy Book Pro 15" Fan Replacement, Remove the fan: step 10, image 3 of 3
      • The fan is lightly adhered to the frame.
      • Lift the fan away from the frame to separate the adhesive.
      • Remove the fan.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
250,475 Reputation
1,201 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,996 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 83
All Time: 1,323
