Samsung Galaxy Book Pro 15" Battery Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
183
All Time:
7,689
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your Galaxy Book Pro 15" Laptop with a genuine Samsung part.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rubber feet: step 1, image 1 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rubber feet: step 1, image 2 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rubber feet: step 1, image 3 of 3
      • Before you begin, power down your laptop and unplug it.
      • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
      • Insert an opening pick between the rubber foot and the rear case.
      • Pry up with the opening pick to release the clips securing the foot.
      • Remove the foot.
      • Repeat this procedure for the three remaining feet.
      • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
      Ask FixBot
    1. Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the rear case: step 2, image 1 of 2 Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the rear case: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
      Ask FixBot
    2. Samsung Galaxy Book Pro 15" Battery Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy Book Pro 15" Battery Replacement, Release the clips: step 4, image 1 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Release the clips: step 4, image 2 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Release the clips: step 4, image 3 of 3
      • Slide the pick along the bottom edge of the rear case to release its plastic clips.
      • Repeat this process for the left and right edges, but stop before reaching the top edge.
      Ask FixBot
    4. Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rear case: step 5, image 1 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rear case: step 5, image 2 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rear case: step 5, image 3 of 3
      • The top edge of the rear case is lightly adhered to the frame.
      • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
      • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
      • Remove the rear case.
      • During reassembly, perform the following:
      • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
      • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
      • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
      Ask FixBot
    1. Samsung Galaxy Book Pro 15" Battery Replacement, Disconnect the battery: step 6, image 1 of 2 Samsung Galaxy Book Pro 15" Battery Replacement, Disconnect the battery: step 6, image 2 of 2
      • Insert a spudger between the frame and the bottom of the battery cable connector.
      • Pry up and disconnect the battery cable connector.
      Ask FixBot
    1. Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the battery: step 7, image 1 of 2 Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the battery: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the battery.
      • Take care not to puncture the battery with your screwdriver—a punctured battery may leak dangerous chemicals or cause a fire.
      Ask FixBot
    2. Samsung Galaxy Book Pro 15" Battery Replacement, Remove the battery: step 8, image 1 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the battery: step 8, image 2 of 3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the battery: step 8, image 3 of 3
      • Lift the battery straight out of the frame and remove it.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
3 other people completed this guide.
Alex Diaz-Kokaisl
250,765 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
1 Guide Comment
what is a spudger? Where do I get the "picks"?
Mitt - Reply Share
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 183
All Time: 7,689
