Samsung Galaxy Amp Prime Battery Replacement
  1. Samsung Galaxy Amp Prime Battery Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Amp Prime Battery Replacement, Battery: step 1, image 2 of 2
    • Before beginning this repair, power off your phone and unplug it from the charger.
    • Use a spudger or your fingernails to pry the back case off, starting at the small slit on the side of the phone.
  2. Samsung Galaxy Amp Prime Battery Replacement: step 2, image 1 of 3 Samsung Galaxy Amp Prime Battery Replacement: step 2, image 2 of 3 Samsung Galaxy Amp Prime Battery Replacement: step 2, image 3 of 3
    • Insert a spudger or your fingernail in the small space at the bottom right where the battery sits to remove it from the phone.
  3. Samsung Galaxy Amp Prime Battery Replacement: step 3, image 1 of 3 Samsung Galaxy Amp Prime Battery Replacement: step 3, image 2 of 3 Samsung Galaxy Amp Prime Battery Replacement: step 3, image 3 of 3
    • Align the four gold contacts at the top of the battery with the top of the battery compartment.
    • Slide the replacement battery in so the gold contacts connect with the matching socket.
  4. Samsung Galaxy Amp Prime Battery Replacement: step 4, image 1 of 1
    • Replace the back case of the phone.
  5. Samsung Galaxy Amp Prime Battery Replacement: step 5, image 1 of 1
    • Finally, charge your phone. Once it's charged, power on your phone.
[deleted]
142 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 57
Past 30 Days: 208
All Time: 3,778
