Samsung Galaxy Amp 2 Screen Replacement
Views: 3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
14
Past 30 Days:
78
All Time:
2,995
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Repair your broken or damaged screen with this guide. A replacement may be needed if the screen is cracked or unresponsive. This guide recommends use of a heat gun, though a blow dryer can be used instead. Use care when applying heat to the screen and carefully detach delicate wiring to avoid damaging the phone.
Parts
Tools
    1. Samsung Galaxy Amp 2 Screen Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Amp 2 Screen Replacement, Battery: step 1, image 2 of 2
      • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
      • Lift upwards and gently pry the rear panel off of the phone.
      Ask FixBot
    2. Samsung Galaxy Amp 2 Screen Replacement: step 2, image 1 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 2, image 2 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 2, image 3 of 3
      • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
      • Grip the battery and safely remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy Amp 2 Screen Replacement, Screen: step 3, image 1 of 3 Samsung Galaxy Amp 2 Screen Replacement, Screen: step 3, image 2 of 3 Samsung Galaxy Amp 2 Screen Replacement, Screen: step 3, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
      • Disconnect the connector piece from the back panel.
      Ask FixBot
    2. Samsung Galaxy Amp 2 Screen Replacement: step 4, image 1 of 1
      • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
      Ask FixBot
    3. Samsung Galaxy Amp 2 Screen Replacement: step 5, image 1 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 5, image 2 of 3 Samsung Galaxy Amp 2 Screen Replacement: step 5, image 3 of 3
      • Use four plastic opening tools to gently pry off the screen.
      • Optional: Use a suction tool to pull the screen off.
      Ask FixBot
6 other people completed this guide.
Cory Nickolatos
430 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Members
60 Guides authored
2 Guide Comments
I broke the screen on the same day I bought the phone. I have ordered a new one from ebay. I am going to try to install the screen with LCD digitizer.
Amresh Kadian - Reply Share
I had an amp 2 phone i accidently smashed it with my ps3 controller when I was playing games I smashed it on purpose so is this the way to fix the phone
darkwatch205 - Reply Share
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 78
All Time: 2,995
