Samsung Galaxy Amp 2 Home Button Replacement
    1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Amp 2 Home Button Replacement, Battery: step 1, image 2 of 2
      • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
      • Lift upwards and gently pry the rear panel off of the phone.
      Ask FixBot
    2. Samsung Galaxy Amp 2 Home Button Replacement: step 2, image 1 of 3 Samsung Galaxy Amp 2 Home Button Replacement: step 2, image 2 of 3 Samsung Galaxy Amp 2 Home Button Replacement: step 2, image 3 of 3
      • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
      • Grip the battery and safely remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy Amp 2 Home Button Replacement, Screen: step 3, image 1 of 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: step 3, image 2 of 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: step 3, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
      • Disconnect the connector piece from the back panel.
      Ask FixBot
    2. Samsung Galaxy Amp 2 Home Button Replacement: step 4, image 1 of 1
      • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
      Ask FixBot
    3. Samsung Galaxy Amp 2 Home Button Replacement: step 5, image 1 of 3 Samsung Galaxy Amp 2 Home Button Replacement: step 5, image 2 of 3 Samsung Galaxy Amp 2 Home Button Replacement: step 5, image 3 of 3
      • Use four plastic opening tools to gently pry off the screen.
      • Optional: Use a suction tool to pull the screen off.
      Ask FixBot
    1. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: step 6, image 1 of 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: step 6, image 2 of 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: step 6, image 3 of 3
      • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
      • Push from the back panel to remove the bottom part of the motherboard.
      • Push from the front panel to remove the top part of the motherboard.
      Ask FixBot
    1. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: step 7, image 1 of 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: step 7, image 2 of 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: step 7, image 3 of 3
      • Pull the black tab that is located on the bottom of the motherboard.
      • Push the home button out of the black tab.
      Ask FixBot
Cory Nickolatos
430 Reputation
4 Guides authored
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 30
All Time: 885
