Up to 20% off select tools
Samsung Galaxy Alpha microSIM Card Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
88
All Time:
3,326
Comments: 0
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide demonstrates how to remove the microSIM card in order to replace it.
    1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: step 1, image 1 of 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: step 1, image 2 of 3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: step 1, image 3 of 3
      • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
      • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
      • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
      Ask FixBot
    1. Samsung Galaxy Alpha microSIM Card Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy Alpha microSIM Card Replacement, Battery: step 2, image 2 of 2
      • Make sure the device is powered down before moving forward.
      • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
      • Locate the slot at the base of the battery and insert your thumb.
      • Push slightly toward the battery and out, away from the phone to free the battery.
      Ask FixBot
    1. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: step 3, image 1 of 1
      • Remove your Micro SIM card from the slot shown.
      Ask FixBot
11 other people completed this guide.
Author
with
Tyler
769 Reputation
1 Guide authored
Cal Poly, Team 20-17, Maness Winter 2015 Member of Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 88
All Time: 3,326
