Samsung Galaxy Alpha Battery Replacement
    1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: step 1, image 1 of 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: step 1, image 2 of 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: step 1, image 3 of 3
      • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
      • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
      • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
      Ask FixBot
    1. Samsung Galaxy Alpha Battery Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy Alpha Battery Replacement, Battery: step 2, image 2 of 2
      • Make sure the device is powered down before moving forward.
      • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
      • Locate the slot at the base of the battery and insert your thumb.
      • Push slightly toward the battery and out, away from the phone to free the battery.
      Ask FixBot
11 other people completed this guide.
Jon Brausch
1,572 Reputation
2 Guides authored
Cal Poly, Team 20-17, Maness Winter 2015 Member of Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Members
60 Guides authored
3 Guide Comments
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - Reply Share
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - Reply Share
Battery change
Ramesh Kayal - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 125
All Time: 6,093
