Up to 20% off select tools
Samsung Galaxy Alpha Back Cover Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
107
All Time:
4,841
Comments: 0
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This simple guide demonstrates how to replace or remove the back cover of your Samsung Galaxy Alpha.
    1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: step 1, image 1 of 3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: step 1, image 2 of 3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: step 1, image 3 of 3
      • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
      • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
      • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
      Ask FixBot
To replace the cover, realign the cover with the device and gently press down until you hear the connections click.
13 other people completed this guide.
Author
with
Sarah
946 Reputation
2 Guides authored
Cal Poly, Team 20-17, Maness Winter 2015 Member of Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 107
All Time: 4,841
