Samsung Galaxy A8 (2018) Display Replacement
    1. Samsung Galaxy A8  (2018) Display Replacement, Display: step 1, image 1 of 1
      • Before proceeding to change the screen of your Galaxy A8 (2018), press and hold the power button to turn off your device.
      Ask FixBot
    2. Samsung Galaxy A8  (2018) Display Replacement: step 2, image 1 of 1
      • Insert the SIM Card Ejection tool into the small hole and remove the SIM Card tray.
      Ask FixBot
    3. Samsung Galaxy A8  (2018) Display Replacement: step 3, image 1 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 3, image 2 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 3, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Using a hairdryer, heat up the back of the device to loosen the adhesive.
      • Gently insert a plastic card and opening pick between the glass and frame to create an opening. Carefully separate the rear glass from the rest of the device.
      • Be careful not to overheat the rear glass since it is very fragile.
      Ask FixBot
    4. Samsung Galaxy A8  (2018) Display Replacement: step 4, image 1 of 2 Samsung Galaxy A8  (2018) Display Replacement: step 4, image 2 of 2
      Buy
      • Using a pair of tweezers, disconnect the clip connecting camera and motherboard.
      • Lift the back panel off of the chassis of the device.
      Ask FixBot
    5. Samsung Galaxy A8  (2018) Display Replacement: step 5, image 1 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 5, image 2 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 5, image 3 of 3
      • Use the P2 Pentalobe screwdriver to remove the 14 (0.8mm) screws.
      • Use the Phillips #0 screwdriver to remove the rest of the four 1.5mm screws.
      • Gently leverage with the spudger under the top antenna to lift it.
      • Continue with the spudger to lift and extract the NFC antenna.
      Ask FixBot
    6. Samsung Galaxy A8  (2018) Display Replacement: step 6, image 1 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 6, image 2 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 6, image 3 of 3
      • Disconnect the battery using the spudger.
      • Gently lift the speaker and pull it out of the slot.
      • Disconnect the display cables from the device.
      Ask FixBot
    7. Samsung Galaxy A8  (2018) Display Replacement: step 7, image 1 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 7, image 2 of 3 Samsung Galaxy A8  (2018) Display Replacement: step 7, image 3 of 3
      • To soften the adhesive that binds the display panel to the chassis, heat the front panel with the hairdryer for a few seconds
      • To create an opening, insert the opening pick gently between the screen and the chassis
      • Gently slide the plastic card around the screen to take it off the chassis.
      • Be careful not to overheat the centre of the display panel as this can damage it.
      Ask FixBot
15 other people completed this guide.
1 Guide Comment
My microphone isnt working please help
alpadarkshadow - Reply Share
Past 24 Hours: 2
Past 7 Days: 44
Past 30 Days: 183
All Time: 12,639
