Samsung Galaxy A7 (2018) Display Assembly Replacement
Views: 22K
View statistics:
Past 24 Hours:
0
Past 7 Days:
26
Past 30 Days:
135
All Time:
22,127
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Video Overview
    1. Samsung Galaxy A7 (2018) Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 Samsung Galaxy A7 (2018) Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
      • It's better to use Display Assembly (Screen With Frame) to fix your broken device.
      Ask FixBot
    2. Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: step 2, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: step 2, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: step 2, image 3 of 3
      • Use hot air to warm the device and soften the adhesive type.
      • Gently separate the back cover.
      • Use Suction Cup and a plastic opening tool (Paying cart).
      Ask FixBot
    3. Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: step 3, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: step 3, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: step 3, image 3 of 3
      • You need a screwdriver Phillips to remove all 9 screws.
      • Again - using only Plastic tools remove the middle frame.
      Ask FixBot
    4. Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: step 4, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: step 4, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: step 4, image 3 of 3
      • Once you have access to the battery, disconnect it.
      • Test the new screen before installing it.
      Ask FixBot
    5. Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub board Cover Removal: step 5, image 1 of 2 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub board Cover Removal: step 5, image 2 of 2
      • Use Phillips Screwdriver and plastic tool and remove the Sub board cover.
      Ask FixBot
    6. Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: step 6, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: step 6, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: step 6, image 3 of 3
      • Remove the black Philips screw and gently take out the Mother board.
      Ask FixBot
    7. Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: step 7, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: step 7, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: step 7, image 3 of 3
      • Remove the Antenna Sub-PBA board.
      • It's easier to take out the sub board if you warm it a little.
      Ask FixBot
    8. Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: step 8, image 1 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: step 8, image 2 of 3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: step 8, image 3 of 3
      • Transfer to the New Screen frame:
      • Vibrator motor
      • Loudspeacker
      • Receiver
      • Use hot air and plastic tools to remove the battery.
      Ask FixBot
    9. Samsung Galaxy A7 (2018) Display Assembly Replacement, That's all friends: step 9, image 1 of 1
      • That's all friends!
      Ask FixBot
22 other people completed this guide.
ZFix
197,729 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
2 Guide Comments
Hey!!!!!!. I’ve just recently fixed my A7 (2018) screen, and with this screen, you’ll have to remove the old one, and replace it. The adhesive what is on your old screen is very strong, So i advise to use isopropyl alcohol, and/or heat, also with suction, so that you can pry up the screen. Also, Do NOT bent the Flex Cable because it is very delicate, and it will tear easy. All in all, the repair was fun, for a repairman myself, and allowed me to use my talent!!. 10/10 Recommend
Marlion Russell - Reply Share
I want buy the screen for samsung a7 ?
Zouhair Guermah - Reply Share
Past 24 Hours: 0
Past 7 Days: 26
Past 30 Days: 135
All Time: 22,127
