Samsung Galaxy A52 Screen Replacement
    1. Samsung Galaxy A52 Screen Replacement, Heat the back cover: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy A52 Screen Replacement, Insert an opening pick: step 2, image 1 of 2 Samsung Galaxy A52 Screen Replacement, Insert an opening pick: step 2, image 2 of 2
      • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
      • If the back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      Ask FixBot
    3. Samsung Galaxy A52 Screen Replacement, Slice the adhesive: step 3, image 1 of 2 Samsung Galaxy A52 Screen Replacement, Slice the adhesive: step 3, image 2 of 2
      • Slide the opening pick to the top right corner to slice the adhesive.
      • Leave the opening pick in its place to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy A52 Screen Replacement: step 4, image 1 of 3 Samsung Galaxy A52 Screen Replacement: step 4, image 2 of 3 Samsung Galaxy A52 Screen Replacement: step 4, image 3 of 3
      • Insert a second opening pick underneath the top right edge of your phone.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy A52 Screen Replacement: step 5, image 1 of 2 Samsung Galaxy A52 Screen Replacement: step 5, image 2 of 2
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom edge of your phone.
      • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy A52 Screen Replacement: step 6, image 1 of 3 Samsung Galaxy A52 Screen Replacement: step 6, image 2 of 3 Samsung Galaxy A52 Screen Replacement: step 6, image 3 of 3
      • Insert a fourth opening pick underneath the bottom left corner of your phone.
      • Slide the opening pick along the left edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy A52 Screen Replacement: step 7, image 1 of 2 Samsung Galaxy A52 Screen Replacement: step 7, image 2 of 2
      • Insert a fifth opening pick underneath the top left corner.
      • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    8. Samsung Galaxy A52 Screen Replacement, Remove the back cover: step 8, image 1 of 1
      • Remove the back cover.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Samsung Galaxy A52 Screen Replacement, Unscrew the motherboard cover: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. Samsung Galaxy A52 Screen Replacement, Pry up the motherboard cover: step 10, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Pry up the motherboard cover: step 10, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Pry up the motherboard cover: step 10, image 3 of 3
      • Insert an opening pick underneath the left edge of the motherboard cover.
      • Use the opening pick to pry up the motherboard cover.
      • Remove the motherboard cover.
      Ask FixBot
    3. Samsung Galaxy A52 Screen Replacement, Disconnect the battery: step 11, image 1 of 2 Samsung Galaxy A52 Screen Replacement, Disconnect the battery: step 11, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Samsung Galaxy A52 Screen Replacement, Disconnect the interconnect cable: step 12, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Disconnect the interconnect cable: step 12, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Disconnect the interconnect cable: step 12, image 3 of 3
      • Use the flat end of a spudger to disconnect the right connector of the interconnect cable from the daugtherboard.
      • Carefully bend the cable to the top of the phone to get access to the screen connector socket.
      Ask FixBot
    2. Samsung Galaxy A52 Screen Replacement, Pry up the screen connector: step 13, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Pry up the screen connector: step 13, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Pry up the screen connector: step 13, image 3 of 3
      • The screen connector is adhered to the daughterboard with mild adhesive.
      • Insert an opening pick underneath the screen connector.
      • Pry up the screen connector.
      Ask FixBot
    3. Samsung Galaxy A52 Screen Replacement, Heat the screen: step 14, image 1 of 1
      • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Ask FixBot
    4. Samsung Galaxy A52 Screen Replacement, Create a gap: step 15, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Create a gap: step 15, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Create a gap: step 15, image 3 of 3
      • Apply a suction handle to the right edge of the screen.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the midframe and the screen.
      Ask FixBot
    5. Samsung Galaxy A52 Screen Replacement, Slice the adhesive: step 16, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Slice the adhesive: step 16, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Slice the adhesive: step 16, image 3 of 3
      • Insert a second opening pick underneath the top right corner and slide it along the right edge to the bottom right corner of the screen to cut the adhesive.
      Ask FixBot
    6. Samsung Galaxy A52 Screen Replacement: step 17, image 1 of 3 Samsung Galaxy A52 Screen Replacement: step 17, image 2 of 3 Samsung Galaxy A52 Screen Replacement: step 17, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to for 1-2 minutes to reheat it.
      • Insert a third opening pick underneath the bottom right corner.
      • Slide the opening pick to the bottom left corner.
      Ask FixBot
    7. Samsung Galaxy A52 Screen Replacement: step 18, image 1 of 3 Samsung Galaxy A52 Screen Replacement: step 18, image 2 of 3 Samsung Galaxy A52 Screen Replacement: step 18, image 3 of 3
      • Insert a fourth opening pick underneath the bottom left corner and slide it along the left edge of the phone to the top left corner.
      Ask FixBot
    8. Samsung Galaxy A52 Screen Replacement: step 19, image 1 of 2 Samsung Galaxy A52 Screen Replacement: step 19, image 2 of 2
      • Insert a fifth opening pick underneath the top left corner and slide it along the top edge to cut the adhesive.
      • When you slice near the front facing camera, insert only the tip of the opening pick (about 3 to 4 mm) to avoid damaging or smearing the camera.
      Ask FixBot
    9. Samsung Galaxy A52 Screen Replacement, Reheat the screen: step 20, image 1 of 2 Samsung Galaxy A52 Screen Replacement, Reheat the screen: step 20, image 2 of 2
      • Reapply a heated iOpener to the screen to loosen the adhesive underneath.
      • In preparation for the following step, take note of the rectangular-shaped adhesive placed underneath the screen.
      Ask FixBot
    10. Samsung Galaxy A52 Screen Replacement, Insert the plastic card: step 21, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Insert the plastic card: step 21, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Insert the plastic card: step 21, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Insert a plastic card on the right edge into the gap between display and the phone assembly.
      • Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
      • Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
      • Do not remove the screen completely yet. The display cable is still threaded through the frame.
      Ask FixBot
    11. Samsung Galaxy A52 Screen Replacement, Remove the screen: step 22, image 1 of 3 Samsung Galaxy A52 Screen Replacement, Remove the screen: step 22, image 2 of 3 Samsung Galaxy A52 Screen Replacement, Remove the screen: step 22, image 3 of 3
      • Carefully thread the screen cable through the frame.
      • Remove the screen.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
39 other people completed this guide.
Adriana Zwink
69,190 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
13 Guide Comments
I can't get the screen removed has anyone tips on how to do this
Seppe De Schutter - Reply Share
Same problem here. Removing the back cover, the battery, and the connectors is fiddly, but not too hard.
However, I have so far failed at the initial step for display removal (#15). Inserting the first tool in between case and battery just seems impossble, despite trying with both an iOpener and a fan for heating. Usually the suction cup gives way before I can exert enough force on the case to create even a tiny gap.
Props to Samsung for creating an extremely sturdy front cover, but not good for display repairability. Perhaps after three years the glue just turns as hard as Roman concrete?
Marcus Groeber - Reply Share
My replacement display did not come with adhesive backing. Other than that everything worked out great. Just waiting on some adhesive strips to arrive before I get my Samsung back into service
Shannon Bish - Reply Share
This guide is good but don't use a card use something thinner like a thin piece of metal. The thing that says "follow this guide for reassembly" shows a screen with a new frame replacement. I pulled the LCD LIKE THIS GUIDE SAID....Now idk what to do so I guess ill wing it...this guide needs work, Adriana Zwink.
Zach Benson - Reply Share
Do you know where I can buy the screen?
Ppp - Reply Share
Past 24 Hours: 45
Past 7 Days: 327
Past 30 Days: 1,369
All Time: 92,112
