Samsung Galaxy A52 Loudspeaker Replacement
    1. Samsung Galaxy A52 Loudspeaker Replacement, Heat the back cover: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy A52 Loudspeaker Replacement, Insert an opening pick: step 2, image 1 of 2 Samsung Galaxy A52 Loudspeaker Replacement, Insert an opening pick: step 2, image 2 of 2
      • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
      • If the back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      Ask FixBot
    3. Samsung Galaxy A52 Loudspeaker Replacement, Slice the adhesive: step 3, image 1 of 2 Samsung Galaxy A52 Loudspeaker Replacement, Slice the adhesive: step 3, image 2 of 2
      • Slide the opening pick to the top right corner to slice the adhesive.
      • Leave the opening pick in its place to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy A52 Loudspeaker Replacement: step 4, image 1 of 3 Samsung Galaxy A52 Loudspeaker Replacement: step 4, image 2 of 3 Samsung Galaxy A52 Loudspeaker Replacement: step 4, image 3 of 3
      • Insert a second opening pick underneath the top right edge of your phone.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy A52 Loudspeaker Replacement: step 5, image 1 of 2 Samsung Galaxy A52 Loudspeaker Replacement: step 5, image 2 of 2
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom edge of your phone.
      • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy A52 Loudspeaker Replacement: step 6, image 1 of 3 Samsung Galaxy A52 Loudspeaker Replacement: step 6, image 2 of 3 Samsung Galaxy A52 Loudspeaker Replacement: step 6, image 3 of 3
      • Insert a fourth opening pick underneath the bottom left corner of your phone.
      • Slide the opening pick along the left edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy A52 Loudspeaker Replacement: step 7, image 1 of 2 Samsung Galaxy A52 Loudspeaker Replacement: step 7, image 2 of 2
      • Insert a fifth opening pick underneath the top left corner.
      • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
      Ask FixBot
    8. Samsung Galaxy A52 Loudspeaker Replacement, Remove the back cover: step 8, image 1 of 1
      • Remove the back cover.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Samsung Galaxy A52 Loudspeaker Replacement, Unscrew the motherboard cover: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. Samsung Galaxy A52 Loudspeaker Replacement, Pry up the motherboard cover: step 10, image 1 of 3 Samsung Galaxy A52 Loudspeaker Replacement, Pry up the motherboard cover: step 10, image 2 of 3 Samsung Galaxy A52 Loudspeaker Replacement, Pry up the motherboard cover: step 10, image 3 of 3
      • Insert an opening pick underneath the left edge of the motherboard cover.
      • Use the opening pick to pry up the motherboard cover.
      • Remove the motherboard cover.
      Ask FixBot
    3. Samsung Galaxy A52 Loudspeaker Replacement, Disconnect the battery: step 11, image 1 of 2 Samsung Galaxy A52 Loudspeaker Replacement, Disconnect the battery: step 11, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    1. Samsung Galaxy A52 Loudspeaker Replacement, Unscrew the loudspeaker assembly: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove the six 4.4 mm-long screws securing the loudspeaker assembly.
      Ask FixBot
    2. Samsung Galaxy A52 Loudspeaker Replacement, Pry up the loudspeaker assembly: step 13, image 1 of 2 Samsung Galaxy A52 Loudspeaker Replacement, Pry up the loudspeaker assembly: step 13, image 2 of 2
      • Insert the pointed end of a spudger into the gap on the right edge of the loudspeaker assembly.
      • Pry up the loudspeaker assembly.
      Ask FixBot
    3. Samsung Galaxy A52 Loudspeaker Replacement, Remove the loudspeaker assembly: step 14, image 1 of 1
      • Remove the loudspeaker assembly.
      • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 other people completed this guide.
Adriana Zwink
68,203 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
83,036 Guides authored
1 Guide Comment
Excellent and very detailed tutorial thank you! Do you know what the impedance of the loudspeaker should normally be? After changing the charging port and reassembling my phone the loudspeaker is not working anymore. Many thanks in advance. Emmanuel
Gfggrrrddd hg - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 135
All Time: 7,778
