Samsung Galaxy A5 (2017) Display Replacement
    1. Samsung Galaxy A5 (2017) Display Replacement, Back Cover Removal: step 1, image 1 of 1
      • Power off your phone before beginning disassembly.
      • Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
      • The adhesive of the Samsung Galaxy A5 (2017) is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy A5 (2017) Display Replacement: step 2, image 1 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 2, image 2 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 2, image 3 of 3
      • Insert an opening pick at the bottom end of your phone.
      • If you can't manage to insert the opening pick between the back cover and the frame, you can use a suction handle to create a small gap.
      • Start to slide the tip of the opening pick to the bottom left corner and cut the adhesive with it.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing. Insert a new opening pick and start to cut the adhesive on the left side of the phone.
      Ask FixBot
    3. Samsung Galaxy A5 (2017) Display Replacement: step 3, image 1 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 3, image 2 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 3, image 3 of 3
      • Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
      • Reuse an iOpener if the adhesive becomes hard to cut. During the removal process the back cover is under tension all the time and is likely to break if the adhesive isn't loose enough.
      • Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
      Ask FixBot
    4. Samsung Galaxy A5 (2017) Display Replacement: step 4, image 1 of 1
      • Remove the back cover from the phone.
      • Before applying new adhesive remove any remaining adhesive from the back cover and the frame and clean the areas with isopropyl alcohol and a lint-free cloth.
      Ask FixBot
    1. Samsung Galaxy A5 (2017) Display Replacement, Motherboard Cover including NFC Antenna and Loudspeaker Removal: step 5, image 1 of 1
      • Remove the eight Phillips #00 screws that hold the motherboard cover in its place.
      Ask FixBot
    2. Samsung Galaxy A5 (2017) Display Replacement: step 6, image 1 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 6, image 2 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift the mother board cover on both upper corners of the phone out of its clamps.
      • Remove the motherboard cover including the NFC antenna and the loudspeaker.
      Ask FixBot
    1. Samsung Galaxy A5 (2017) Display Replacement, Battery Disconnection: step 7, image 1 of 1
      • Use the flat end of a spudger to disconnect the battery flex cable.
      Ask FixBot
    1. Samsung Galaxy A5 (2017) Display Replacement, Display Replacement: step 8, image 1 of 1
      • Use the flat end of a spudger and disconnect the display flex cable.
      Ask FixBot
    2. Samsung Galaxy A5 (2017) Display Replacement: step 9, image 1 of 1
      • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. Samsung Galaxy A5 (2017) Display Replacement: step 10, image 1 of 2 Samsung Galaxy A5 (2017) Display Replacement: step 10, image 2 of 2
      • Once the display is warm to the touch, apply a suction cup to the upper edge of the phone.
      • Lift on the suction cup, and insert an opening pick under the display assembly.
      • Start to slide the opening pick along the upper edge of the phone to cut the adhesive. Leave an opening pick at the corner to prevent the adhesive from resealing.
      • The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
      • Continue to slide the tip of the opening pick along the side towards the bottom of the phone to cut the adhesive.
      Ask FixBot
    4. Samsung Galaxy A5 (2017) Display Replacement: step 11, image 1 of 2 Samsung Galaxy A5 (2017) Display Replacement: step 11, image 2 of 2
      • Leave an opening pick on the bottom left edge of the phone to prevent the adhesive from resealing.
      • The home button and soft key cables are located beneath the bottom part of the display assembly. Only insert the tip of the opening pick.
      • Carefully slide the tip along the bottom edge of the phone to cut the adhesive.
      • Continue to cut the adhesive on the remaining sides of the phone and leave an opening pick in each corner.
      Ask FixBot
    5. Samsung Galaxy A5 (2017) Display Replacement: step 12, image 1 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 12, image 2 of 3 Samsung Galaxy A5 (2017) Display Replacement: step 12, image 3 of 3
      Buy
      • Don't open the phone all the way yet. The display cable is still threaded through the mid frame and you might rip the cables of the home and menu buttons.
      • Start to carefully lift the upper edge of the display assembly and thread the display flex cable through the mid frame.
      • Check if the home button or soft key button cables sticks to the display assembly before your remove the display all the way.
      • In case one of the cables sticks to the display, carefully peel them of with a pair of tweezers or an opening pick.
      Ask FixBot
    6. Samsung Galaxy A5 (2017) Display Replacement: step 13, image 1 of 1
      • Remove the display assembly from the phone.
      • Before reassembling make sure to remove any remaining adhesive from the frame by using isopropyl alcohol (>97%) and a lint-free cloth or Q-tip.
      Ask FixBot
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the mid frame. Align the screen and press it into place.
45 other people completed this guide.
Dominik Schnabelrauch
266,119 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
3 Guide Comments
If the screen is not found is there any alternative screen that can work A5 screen
Adetokun Joseph adeoye - Reply Share
If possible how would I know or find the circuit diagram of the A5 Screen
Gazaking - Reply Share
You should get some adhesive tape to remeount the whole thing. Not mentioned in the furnitures needed. Don't forget it !
Plus, on the tutorial dedicated to the display replacement of the galaxy A5 (2015), the year is not mentioned --> I followed this first on the first place.
And, thanks for all these awesome guides <3
Max Rob - Reply Share
Past 24 Hours: 9
Past 7 Days: 51
Past 30 Days: 188
All Time: 51,080
