Samsung Galaxy A5 (2017) Back Cover Replacement
Views: 42K
View statistics:
Past 24 Hours:
2
Past 7 Days:
35
Past 30 Days:
137
All Time:
41,682
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the back cover of your Samsung Galaxy A5 2017 smartphone.
Opening the Samsung Galaxy A5 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
If needed, you can use a dropper or syringe to inject isopropyl alcohol (>97%) around the edges of the back cover to weaken the adhesive.
You’ll need replacement adhesive to reattach the back cover when reassembling the device.
Tools
    1. Samsung Galaxy A5 (2017) Back Cover Replacement, Back Cover Removal: step 1, image 1 of 1
      • Power off your phone before beginning disassembly.
      • Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
      • The adhesive of the Samsung Galaxy A5 (2017) is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy A5 (2017) Back Cover Replacement: step 2, image 1 of 3 Samsung Galaxy A5 (2017) Back Cover Replacement: step 2, image 2 of 3 Samsung Galaxy A5 (2017) Back Cover Replacement: step 2, image 3 of 3
      • Insert an opening pick at the bottom end of your phone.
      • If you can't manage to insert the opening pick between the back cover and the frame, you can use a suction handle to create a small gap.
      • Start to slide the tip of the opening pick to the bottom left corner and cut the adhesive with it.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing. Insert a new opening pick and start to cut the adhesive on the left side of the phone.
      Ask FixBot
    3. Samsung Galaxy A5 (2017) Back Cover Replacement: step 3, image 1 of 3 Samsung Galaxy A5 (2017) Back Cover Replacement: step 3, image 2 of 3 Samsung Galaxy A5 (2017) Back Cover Replacement: step 3, image 3 of 3
      • Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
      • Reuse an iOpener if the adhesive becomes hard to cut. During the removal process the back cover is under tension all the time and is likely to break if the adhesive isn't loose enough.
      • Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
      Ask FixBot
    4. Samsung Galaxy A5 (2017) Back Cover Replacement: step 4, image 1 of 1
      • Remove the back cover from the phone.
      • Before applying new adhesive remove any remaining adhesive from the back cover and the frame and clean the areas with isopropyl alcohol and a lint-free cloth.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
23 other people completed this guide.
Dominik Schnabelrauch
266,185 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
4 Guide Comments
Back glass price
Amjad Ali - Reply Share
genial, tutorial paso a paso pregunta cual es el adhesivo que se utiliza ???
Erik Astudillo - Reply Share
Hi Erik, you can buy precut and for the A5 optimized back cover adhesive or the precut adhesive card in our shop.
Dominik Schnabelrauch - Reply Share
Where can you buy the back glass?
The JoMan - Reply Share
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 137
All Time: 41,682
