Samsung Galaxy A41 Display Replacement
      • Found this video on how to do the repair. Worked perfectly.
      Ask FixBot
    1. Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      Ask FixBot
      • Prepare the necessary repair materials. Make sure you have everything before you start.
      Ask FixBot
      • Make sure you are working with the right model. In this case, it is a Samsung Galaxy A41 (SM-A415F), in white.
      Ask FixBot
      • In this video, the screen was damaged by a blow to the left side. This requires a complete display replacement.
      Ask FixBot
      • You need a new replacement display for your Samsung Galaxy A41. If you want the same display quality again, you need to make sure that it is a Super AMOLED display.
      Ask FixBot
    2. Tool used on this step:
      Heat Gun
      $29.99
      Buy
      Ask FixBot
      • Clean the surface and remove any adhesive residue to ensure that the new screen is clean and flush.
      Ask FixBot
      • Carefully position the new display so that you can reconnect all the cables.
      Ask FixBot
      • Turn on the device and check if the new display is working correctly.
      Ask FixBot
Congratulations! You've done it and successfully replaced the display on your Samsung Galaxy A41.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
riiedl95
143 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 49
Past 30 Days: 170
All Time: 6,070
