Introduction
If your Galaxy A3 won't hold a charge you can use this guide to replace the worn-out battery.
This guide involves removing the display and the midframe. You will need replacement adhesive to reattach the display. The LCD is also glued to the frame and is likely to break when opening the phone.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
If your battery is swollen, take appropriate precautions.
Switch off your phone.
Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
Remove the ten Phillips #00 screws.
Lift up the two touch sensors in the lower area of the frame with a spudger. You can skip this step if you are careful while removing the mid frame from the back cover later.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
47 other people completed this guide.
11 Guide Comments
Ich habe die Metallfolie abgemacht und jetzt geht das Handy gar nicht mehr an! Ist das normal oder müsste es zumindest einmal vibrieren, selbst wenn kein LCD angeschlossen ist? Habe noch sehr wichtige Daten auf dem Handy ….
Why does it not mention that the screen is glued to the frame (not just around the edges)? I have now found the ifixit guide for replacing the screen that says “NOTE: The LCD is also glued to the frame and will most likely break when removing the display“. Seems a pretty important bit of information to leave out of this article when the screen needs to be removed in one piece, and one that’s just cost me a screen. Not happy.
Actually, he does say it. Esta guía incluye cómo quitar la pantalla y el marco intermedio. Necesitarás adhesivo de reemplazo para volver a pegar la pantalla. —>>>> La pantalla LCD también está pegada al marco y podría romperse al abrir el teléfono. <<<<—
Do you really have to take the screen off just to replace the back cover
There is no real back cover, rather a complete casing. Unfortunately the display is the only way in.
