Samsung Galaxy A3 (2017) Battery Replacement
    1. Samsung Galaxy A3 (2017) Battery Replacement, Back cover replacement: step 1, image 1 of 1
      • Power off your phone before beginning disassembly.
      • Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
      • The adhesive of the Samsung Galaxy A3 (2017) is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy A3 (2017) Battery Replacement: step 2, image 1 of 3 Samsung Galaxy A3 (2017) Battery Replacement: step 2, image 2 of 3 Samsung Galaxy A3 (2017) Battery Replacement: step 2, image 3 of 3
      • Use a small suction handle to create a gap at the bottom end of the Galaxy A3.
      • Insert an opening pick and slide the tip to the bottom left corner to cut the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      • Insert a new opening pick and start to cut the adhesive towards the bottom left side of the phone.
      Ask FixBot
    3. Samsung Galaxy A3 (2017) Battery Replacement: step 3, image 1 of 3 Samsung Galaxy A3 (2017) Battery Replacement: step 3, image 2 of 3 Samsung Galaxy A3 (2017) Battery Replacement: step 3, image 3 of 3
      • Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
      • Reuse an iOpener if the adhesive becomes hard to cut. During the removal process the back cover is under tension all the time and is likely to break if the adhesive isn't loose enough.
      • Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
      Ask FixBot
    4. Samsung Galaxy A3 (2017) Battery Replacement: step 4, image 1 of 1
      • Remove the back cover from the phone.
      • Before applying new adhesive remove any remaining adhesive from the back cover and the frame and clean the areas with isopropyl alcohol and a lint-free cloth.
      Ask FixBot
    1. Samsung Galaxy A3 (2017) Battery Replacement, Motherboard cover including NFC antenna and loudspeaker replacement: step 5, image 1 of 1
      • Remove the five Phillips #00 screws that hold the motherboard covers in their place.
      Ask FixBot
    2. Samsung Galaxy A3 (2017) Battery Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the upper part of the motherboard cover.
      • The cover is secured by small plastic clamps. Don't break them during the removal procedure.
      Ask FixBot
    3. Samsung Galaxy A3 (2017) Battery Replacement: step 7, image 1 of 1
      • Use a pair of tweezers to lift up the motherboard cover including the loudspeaker and the NFC antenna and remove it.
      Ask FixBot
    1. Samsung Galaxy A3 (2017) Battery Replacement, Battery Disconnect: step 8, image 1 of 1
      • Use the flat end of a spudger to disconnect the battery flex connector.
      Ask FixBot
    1. Samsung Galaxy A3 (2017) Battery Replacement, Battery removal: step 9, image 1 of 1
      Ask FixBot
    2. Samsung Galaxy A3 (2017) Battery Replacement: step 10, image 1 of 2 Samsung Galaxy A3 (2017) Battery Replacement: step 10, image 2 of 2
      • Insert the flat end of a spudger in the bottom right gap of the battery and start to pry it up just a bit.
      • Move the spudger to the bottom left corner of the battery and also pry it up a bit.
      • Only insert the spudger as far as the notch on its flat end. See next step for further procedure.
      Ask FixBot
    3. Samsung Galaxy A3 (2017) Battery Replacement: step 11, image 1 of 2 Samsung Galaxy A3 (2017) Battery Replacement: step 11, image 2 of 2
      • Caution when continuing:
      • Only pry in the areas marked in yellow (rim).
      • Avoid prying in the area marked in red (center). This is the back side of the display.
      • Insert the spudger beneath the battery on the sides of the recess to cut the remaining adhesive until the battery is loose.
      Ask FixBot
    4. Samsung Galaxy A3 (2017) Battery Replacement: step 12, image 1 of 1
      • Remove the battery.
      Ask FixBot
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape and press it firmly into place for 5-10 seconds.
For optimal performance and to avoid software sided errors, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
18 other people completed this guide.
Dominik Schnabelrauch
265,703 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
5 Guide Comments
La batteria nuova,presenta la protezione, ovviamente tolta ma rimane ancora la colla
Immagino vada tolta per consentire di fare contatto con il display tack??!
gloriagiannecchini4 - Reply Share
Ho sostituito la batteria al mio Samsung a3, sul retro vi è resto di colla dovuta alla protezione. Immagino vada tolta per far contatto. Giusto?
Very instructive and easy to follow battery replacement guide!
CSD
Carsten S Due - Reply Share
Unfortunately I had no iOpener or proper spudgers at my disposal, so I found that a pretty thin and flat plastic (!) spatula and a hairdryer also worked. The spatula was about as wide as the battery and fit perfectly in the pocket near the bottom of the phone and the battery. A bit of gentle heat from the hairdryer and by using the spatula as a lever the battery popped out in no time.
Thomas - Reply Share
Hi, My Samsung Galaxy A3 2017 gets hanged while running and shuts down while two buttons stay lit for a few seconds then totally shut down and I have to start it with volume down and power button, or else it doesn't start. It happens many times in a day. can this be a battery issue? Also sometimes the first system doesn't work too then I disconnect the battery and connect it to the charger then I disconnect the charger and connect the battery and if I press the power button it starts again. Can this be a battery issue? Any idea? Thanks in advance.
Harry Potter - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 199
All Time: 50,119
