This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Samsung Galaxy A20e Vibration Module Replacement
      • For obvious safety reasons, it is necessary to completely turn off your device before opening it.
      • Then, using your SIM eject tool inserted into the hole on the side of your phone, eject the SIM card tray and set everything aside.
      Ask FixBot
      • Take a pick and slide it between the back cover of the phone and the screen.
      • Tip: It’s easier to insert the tool near the SIM card slot or at one of the phone’s corners to get started!
      • Slide the pick tool along the screen to unclip the entire back cover of the phone.
      • Caution: The fingerprint sensor may be attached to the back cover. Carefully pull on the sensor while preserving the connection ribbon to remove it.
      Ask FixBot
      • Slide the spudger under the sensor’s connector and gently pry it up to unplug the module.
      • Place the sensor in a safe location until you have completed repairing your device!
      Ask FixBot
      • Using a Phillips screwdriver, remove the 6 screws securing the plastic covers.
      • Lift these plastic covers (using a spudger) to remove them.
      • Just like the fingerprint sensor, store the covers in a safe place!
      Ask FixBot
      • Using the nylon spudger, lift and disconnect the ribbon cables for the battery, screen, and charging connector.
      • This step is partly for safety to avoid any risk of a short circuit during the operation.
      • Similarly, disconnect the ribbon cables for the buttons (power and volume) and the front camera as well as the GSM (white) and WiFi/Bluetooth (blue) interconnect cables.
      • Since the front camera is completely detached from the rest of the phone, store it safely in a secure place to prevent any damage.
      Ask FixBot
      • Gently lift the component to detach it from the rest of the device. You can then place it in a safe location.
      Ask FixBot
      • À l'aide d'un tournevis plat (les spatules sont trop larges pour s'immiscer), soulevez délicatement le module vibreur afin de l'ôter de l'appareil.
      • Peel off the protective adhesive from your new module, and place it in the same position as the old one, on the designated spot at the bottom of the phone.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Passion Fabrication
1,053 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 72
All Time: 610
